3c905 Nic configuration
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Oct 3 16:32:04 CDT 2007
Stéphane ARQUER wrote:
> Hello Joel,
> Thanks a lot, it's working correctly. To extend the config I tried on
> another machine ( a more recent one) but the pcibios file return at the
> line 80: "BIOS-32 not found".
> I don't know if my motherboard (Intel D975XBX) support BIOS32 ?
> In the case of not, Is there another pci driver comparible with these
> kind of bios ?
I don't know why this would fail. Can you put printk's on each
of the failure conditions in libbsp/i386/pc386/shared/pci/pcibios.c.
It could not be finding the PCI BIOSes or main PC BIOS if I
am reading the code correctly.
It might be a BIOS setting on your PC. What BIOS is in it?
--joel
> Thanks.
> Stephane.
>>> Effectively I need to configure MAXIMUM_MESSAGE_QUEUES to.
>>> Now the driver is attached correctly and there is a problem with the
>>> webserver init due to the host adress:
>>> Can't get host adress
>>> There is something wrong with the IP adress ??
>> That's in the networkconfig.h
>>> Is it in webmain.c (198) or in the networkconfig.h file ?
>> The hostname in networkconfig.h has to match the
>> host name in the rootfs/etc/hosts that is put on the
>> target.
>>> Thanks.
>>> Stephane.
> Stéphane ARQUER
> CSSI - Division Aéronautique, Logiciels Embarqués
> email: stephane.arquer at c-s.fr
More information about the rtems-users
