panic error with powerpc/virtex BSP
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Oct 2 07:01:16 CDT 2007
Jukka Pietarinen wrote:
> Pierre,
> Pierre Kestener wrote:
>> I am having problems in running the RTEMS helloworld example on a
>> ML405 board (very similar to ML403). I made the FPGA design with the
>> Xilinx EDK tool and then modified the xparameters_dflt.h that is in
>> the RTEMS BSP with the one generated by EDK.
>> When running the helloworld, i receive the following output:
>> opb_intc_init: mask = 0x7
>> rtems-4.7.99.2(PowerPC/PowerPC 405/virtex) PANIC ERROR 5
>> system stopped, press RESET
>> I am not sure to what refer the number 5 as a PANIC ERROR. Has
>> someone an idea of what could done here ?
> I think there is a problem with the linkcmds of the virtex BSP in
> 4.7.99.2. The linker script defines _end to be at the end of the .data
> section whereas I think it should be defined to be at the end of .bss.
> Please correct me if I'm wrong.
> Attached please find diff against a linkcmds I'm using for a Virtex II
> Pro board.
I will commit this to the 4.8 branch and CVS head. We went through this
back in August and I proposed a similar patch. I don't know how it didn't
get merged.
--joel
> HTH.
> Regards,
> Jukka
> Jukka Pietarinen
> Micro-Research Finland Oy
> rtems-users mailing list
> rtems-users at rtems.com
More information about the rtems-users
