Problems initializing Network driver on MCF5235 Coldfire
CWolfe at motioncontrol.org
Thu Jun 21 08:29:51 CDT 2007
I Forwarded my responses to the list, but I'll summarize what's going on....
I can compile/upload/execute all(I believe) of the samples from the testsuites.
when I try to initialize the network using a non-loopback interface, the execution
dips into some black hole where I can't trace it. I have been able to trace the code into
http.c::init()
|--rtems_glue.c::rtems_bsdnet_initialize_network()
|--rtems_glue.c::rtems_bsdnet_initialize()
| |--rtems_glue.c::bsd_init()
| |--blah blah blah <makes it past all of this>
|--rtems_glue.c::rtems_bsdnet_attach(ifp)
| |-- blah blah blah <makes it past all of this>
| |--rtems_glue.c::rtems_bsdnet_setup()
|--rtems_glue.c::rtems_bsdnet_ifconfig()
|---rtems_glue.c::rtems_bsdnet_semaphore_obtain()
|--blah blah blah <makes it past call to ioctl which I
believe "UP"s the interface...???>
|---rtems_glue.c::rtems_bsdnet_semaphore_release()
<======here it dies, on/while returning from semaphore_release()>
but i can't trace any further into it. At Joel's Suggestion, I added some LEDs to the board to
use in trouble shooting, but as of right now, I don't know where in the code to look/place
debugging code...
Thank you for your time.
Christopher Wolfe
Motion Control Systems, Inc.
On 21 Jun 2007 at 17:17, Chris Johns wrote:
> Hi Chris,
> Please cc me with responses. I know the Coldfire and the driver well enough to
> aid you in getting the web server to work.
> Regards
> Chris
> Joel Sherrill wrote:
> > CWolfe at motioncontrol.org wrote:
> >> On 20 Jun 2007 at 9:36, Joel Sherrill wrote:
> >>> I actually don't have a 5235 so I have cc'ed Chris Johns since
> >>> I think he is way more familiar with the Coldfire BSPs.
> >>> This type of question is usually best asked on the list. There
> >>> are many people out there who and more eyes is good.
> >> what is the address to send to?
> > You have to be subscribed... see
> > http://www.rtems.org/wiki/index.php/RTEMSMailingLists
> > for instructions.
> > If you spot something wrong in the Wiki, feel free
> > to create an account and fix it.
> >>> My usual first questions are:
> >>> + Can you run ticker?
> >> haven't tried yet, will do so now.
> > If the clock tick interrupt isn't working, then
> > things aren't in good shape.
> >>> + Can you run netdemo?
> >> no, same issue with crashing on driver init (after releasing semaphore)
> > Maybe you are dying in the interrupt handler. Do you have some type of
> > exception handler of debugger
> > that can point you to an address. If not, do you have
> > an LED you could blink or some other bread crumb
> > you could post to note you entered the ISR.
> >>> + Are you using RPMs or your own tool builds.
> >> using cygwin so....
> >> own build tools. versions and patches are as follows <excerpted from
> >> our in-house toolchain build script>......
> >> GCC=gcc-4.1.1
> >> BINUTILS=binutils-2.17
> >> NEWLIB=newlib-1.14.0
> >> BDM=m68k-bdm-1.3.0
> >> GDB=gdb-6.0
> >> INSIGHT=insight-6.0
> >> AUTOCONF=autoconf-2.61
> >> AUTOMAKE=automake-1.10
> >> i'm actually not sure which patches have been appplied as the script
> >> automatically applies them. if necessary, i can dig into them and
> >> figure out which ones are actually applied, but i assume they are the
> >> most recent...
> > Are you sure about newlib 1.14? The 4.7 branch
> > should be built against 1.15.
> > This isn't likely to be your problem but normally
> > RTEMS versions are carefully matched against
> > a specific newlib version and patch.
> >>>> Dear Joel, My name is Christopher Wolfe, and I am an Intern
> >>>> working for Motion Control Systems. Currently, I am working on an
> >>>> embedded management project with the coldfire 5235BCC eval board. I
> >>>> am having trouble with getting the webserver up and running, and I
> >>>> was wondering if you might know what I could do next to find the
> >>>> problem. I have based my code off of the http example, but I have
> >>>> had to make a few minor modifications to allow it to compile, as
> >>>> directories and whatnot are moved, etc. Anyway, when I upload the
> >>>> code and run it, it crashes in the network driver initialization. I
> >>>> have traced the execution as far into the code as I am able, but I
> >>>> lose track at specific point.
> >>>> execution makes it thru:
> >>>> http.c::init()
> >>>> |--rtems_glue.c::rtems_bsdnet_attach(ifp) | |-- blah blah
> >>>> |--rtems_bsdnet_ifconfig()
> >>>> |---rtems_glue.c::rtems_bsdnet_semaphore_release() <here
> >>>> it dies>
> >>>> as soon as the semaphore is released, i lose track of the execution
> >>>> of the code. where it should return to rtems_bsdnet_ifconfig(), it
> >>>> is not. debugging printf statements were placed as the very last
> >>>> statement inside the semaphore release code, and the first statement
> >>>> in rtems_bsdnet_ifconfig() after the call to release the semaphore.
> >>>> of the the two statements which should be executed, only the first
> >>>> is executed. afterwards, execution progresses into the
> >>>> rtems_bsdnet_semaphore_release's exit code.... never to return to
> >>>> the calling function .... and hence it is lost and i can't trace
> >>>> it with the tools i have.....
> >>>> At this point in the initialization, what is going on? Are there
> >>>> other rtems processes which are taking control? where does the
> >>>> execution go after releasing that semaphore? what configuration
> >>>> issues could cause this symptom set?<<<i assume this to be the
> >>>> problem, but i just don't know enough about rtems yet>>>
> >>>> I include the configuration options/code i am using below.....
> >>>> <<changes to makefile>>
> >>>> LDFLAGS += -qnolinkcmds -T linkcmdsflash
> >>>> LD_LIBS += -lhttpd -lftpd
> >>>> <<changes to init.c>>
> >>>> #include <rtems/confdefs.h>
> >>>> #include <rtems/ftpd.h>
> >>>> << some printf()'s for debugging>>
> >>>> <<changes to system.h>>
> >>>> #include "tmacros" (file was not
> >>>> in include directory, but I copied it from the testsuites build
> >>>> directory)
> >>>> otherwise, everything is the same as the example source. I am using
> >>>> rtems 4.7.1. Thank you for your time, and I would greatly appreciate
> >>>> any help you could give.
> >>>> Best Regards,
> >>>> Christopher Wolfe
URL: <http://www.rtems.org/pipermail/rtems-users/attachments/20070621/0b7e49ae/attachment.html>
More information about the rtems-users
