possible issue with bss section in sparc
Stephan Gruenfelder
stephan.gruenfelder at space.at
Wed Aug 29 03:26:27 CDT 2007
Hi Aleix,
if "std" accesses data, which is not 8-bytes aligned, the SPARC processor would
trap (i.e. stop operating in most conditions). It that is your "weird" behaviour
than your observation makes sense.
Regards
Stephan
Aleix Conchillo Flaqué wrote:
> Hi all,
> yesterday I changed some dynamic allocated arrays of structures to
> static arrays and the application I am working on had a really weird
> behaviour. I changed the array to dynamic and everything worked
> properly again. So, after a couple of hours I started thinking that it
> could be a problem of the bss section (a moment of desperation I
> guess).
> I had a look at the linker script
> (c/src/lib/libbsp/sparc/erc32/startup/linkcmds):
> .bss :
> __bss_start = ALIGN(0x8);
> _bss_start = .;
> bss_start = .;
> *(.bss)
> *(COMMON)
> end = .;
> _end = ALIGN(0x8);
> __end = ALIGN(0x8);
> } > ram
> And at the startup code (c/src/lib/libbsp/sparc/shared/start.S):
> /* clear the bss */
> 1:
> sethi %hi(_edata),%g2
> or %g2,%lo(_edata),%g2 ! g2 = start of bss
> sethi %hi(_end),%g3
> or %g3,%lo(_end),%g3 ! g3 = end of bss
> mov %g0,%g1 ! so std has two zeros
> zerobss:
> std %g0,[%g2]
> add %g2,8,%g2
> cmp %g2,%g3
> bleu,a zerobss
> nop
> And I thought it could be a problem on the alignment of the bss
> section, which aligns to the next byte, and the instruction "std
> %g0,[%g2]" which stores 8 bytes at the same time. I'm not an expert on
> this, so this was another moment of desperation.
> I tried out two separate things: first, change the alignment to
> ALIGN(16), and second, change the assembly to (keeping ALIGN(8)):
> stb %g0,[%g2]
> add %g2,1,%g2
> Both things worked well. So, I'm wondering if that makes any sense at
> all. Could it be that the "std" is overwriting some bytes that it
> should not? Should I find the error in my application, probably a
> memory issue, because the bss thing doesn't make any sense?
> Any clues would be really appreciated.
> Thanks in advance,
> Aleix
> rtems-users mailing list
> rtems-users at rtems.com
Stephan GRUENFELDER
Dr.techn., Software Engineer
Tel. : +43-1-80199/5530
Fax : +43-1-80199/5577
E-Mail: stephan.gruenfelder at space.at
AUSTRIAN AEROSPACE GmbH
Stachegasse 16
A-1120 Vienna, AUSTRIA / EUROPE
FN 91260 g Handelsgericht Wien
www.space.at
This e-mail is for information only. Any contractual obligations require a confirmation by a company fax or letter.
This e-mail and any file attached to it may contain confidential information. If you are not the intended recipient, please delete this e-mail from your system immediately and notify us of the erroneous transmission; any other use of this e-mail is prohibited.
More information about the rtems-users
