possible issue with bss section in sparc
Aleix Conchillo Flaqué
aconchillo at ieec.cat
Wed Aug 29 02:46:53 CDT 2007
Hi all,
yesterday I changed some dynamic allocated arrays of structures to
static arrays and the application I am working on had a really weird
behaviour. I changed the array to dynamic and everything worked
properly again. So, after a couple of hours I started thinking that it
could be a problem of the bss section (a moment of desperation I
guess).
I had a look at the linker script
(c/src/lib/libbsp/sparc/erc32/startup/linkcmds):
.bss :
__bss_start = ALIGN(0x8);
_bss_start = .;
bss_start = .;
*(.bss)
*(COMMON)
end = .;
_end = ALIGN(0x8);
__end = ALIGN(0x8);
} > ram
And at the startup code (c/src/lib/libbsp/sparc/shared/start.S):
/* clear the bss */
1:
sethi %hi(_edata),%g2
or %g2,%lo(_edata),%g2 ! g2 = start of bss
sethi %hi(_end),%g3
or %g3,%lo(_end),%g3 ! g3 = end of bss
mov %g0,%g1 ! so std has two zeros
zerobss:
std %g0,[%g2]
add %g2,8,%g2
cmp %g2,%g3
bleu,a zerobss
nop
And I thought it could be a problem on the alignment of the bss
section, which aligns to the next byte, and the instruction "std
%g0,[%g2]" which stores 8 bytes at the same time. I'm not an expert on
this, so this was another moment of desperation.
I tried out two separate things: first, change the alignment to
ALIGN(16), and second, change the assembly to (keeping ALIGN(8)):
stb %g0,[%g2]
add %g2,1,%g2
Both things worked well. So, I'm wondering if that makes any sense at
all. Could it be that the "std" is overwriting some bytes that it
should not? Should I find the error in my application, probably a
memory issue, because the bss thing doesn't make any sense?
Any clues would be really appreciated.
Thanks in advance,
Aleix
More information about the rtems-users
