How to debug networking codes?
Till Straumann
strauman at slac.stanford.edu
Fri Aug 24 21:48:27 CDT 2007
Rahman, Md Sazzadur wrote:
> Hi,
> Thanks for your suggestion. Lately I was trying to debug networking codes for SCTP in RTEMS via serial port using rtems_gdb_stub_1.4(http://www.slac.stanford.edu/~strauman/rtems/gdb/index.html). But, I was not able to connect target machine from the host using serial port although I was able to connect them using TCP/IP.
> In target init.c: I have added,
> init_remote_gdb(); //just to initialize serial port in RTEMS. It is defined: /c/src/lib/libbsp/i386/shared/comm/gdb_glue.c
I don't recall what this routine does and if it is compatible with
my stub. I'd have to check...
> rtems_gdb_start(0,"/dev/ttyS0");
> rtems_gdb_breakpoint();
> The console shows:
> GDB daemon (Release $Name: RTEMS_gdb_stub_1_4 $): starting up
> In host: I was running GDB6.6 for target i386-ssrl-rtems
did you set the baudrate of the host gdb to 115200 ?
T.
> (gdb) target rtems-remote /dev/ttyS0
> Remote debugging using /dev/ttyS0
> Ignoring packet error, continuing...
> warning: unrecognized item "timeout" in "qSupported" response
> Malformed response to offset query, timeout
> (gdb)
> // Using /dev/ttyS0 of this host, I could transfer and receive data with other Linux machines.
> Is there anything I am missing here? I would appreciate any help in this regard.
> -Sazzad
> -----Original Message-----
> From: Till Straumann [mailto:strauman at slac.stanford.edu]
> Sent: Wednesday, August 22, 2007 12:20 PM
> To: Rahman, Md S.
> Cc: rtems-users at rtems.com
> Subject: Re: How to debug networking codes?
> RTM.
> You cannot debug networking code. If you set a breakpoint in
> networking and e.g., the network task is suspended at the breakpoint
> -- how do you expect the stub to continue talking to the host gdb
> using the same network stack???
> If you want to debug networking then you should use GDB on a serial
> connection (preferrably a separate serial port where no printf/printk
> is directed).
> HTH
> -- Till
> Rahman, Md S. wrote:
>> Hello,
>> I have been porting SCTP(Stream Control Transmission Protocol) in
>> RTEMS from FreeBSD. This is a transport layer protocol and resides
>> with TCP/UDP networking codes in kernel. I am mostly done with this
>> port and a number of SCTP socket API's like socket, listen, bind,
>> accept, connect etc. works fine.
>> However, I am now encountering some exception problems while
>> establishing SCTP connection between RTEMS SCTP endpoint with FreeBSD
>> SCTP endpoint via internet. The console shows:
>> Exception 6 caught at PC 191864 by Thread 167831697
>> Processor execution context at time of the fault was:
>> EAX 340012E7 EBX=384 ECX=FFFFFFFF EX=0
>> ESI=0 EDI=0 EBP=195838 ESP=195804
>> Error code pushed by processor itself (if not 0) = 0
>> Faulty Thread will be deleted
>> I tried to debug this problem by adding printf in codes but was not
>> able to detect the exact statement which causes this exception. Then I
>> have built RTEMS_GDB_Stub_1.4
>> <http://www.slac.stanford.edu/%7Estrauman/rtems/gdb/index.html>) for
>> remote debugging and built my RTEMS SCTP application with
>> librtems-gdb-stub.a library. At this point, running the RTEMS
>> application crashes with:
>> GDB Agent: Exception (SIGILL) caught; Task 0xA010001 Killed
>> (Suspended) -use GDB
>> Exception Vector #0x6; Registers:
>> To investigate further with breakpoints, I have configured gdb6.6
>> patched with RTEMS_GDB_Stub_1.4 in the host machine FC5. This works
>> fine and any break point in RTEMS application in init.c could be
>> reachable by the host gdb. However, when I try to reach a breakpoint
>> in SCTP code which resides in cpukit/libnetworking/netinet, host gdb
>> loses connection with the target machine and target application dies.
>> In this point, I am not sure how should I proceed to solve this problem.
>> I would appreciate any suggestion in this regard.
>> Best Regards,
>> Md Sazzadur Rahman
>> Graduate Student,
>> School of Computer Science,
>> University of Oklahoma,
>> Norman, Oklahoma, USA
>> rtems-users mailing list
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
More information about the rtems-users
