OT (maybe) How to create a library of libraries
Chris Johns
chrisj at rtems.org
Tue Aug 21 16:50:11 CDT 2007
Robert S. Grimes wrote:
> So I created a new library (in projectroot/libs/uberlib) that has
> another Makefile.lib-based Makefile, except instead of putting object
> files into the output library, it puts the other libraries.
This will not work. The linker does not know the library is a library of
libraries. The linker will only work with a library of object files. You need
to *merge* the libraries.
> Am I missing something? Or more accurately, what am I missing?
There is no standard way to do this. It is often hand crafted to suit your
build system specifics. A nice example is already in RTEMS and used to build
the librtemscpu.a library. Take a look in:
cpukit/wrapup/Makefile.am
and search for 'librtemscpu.a: $(TMP_LIBS)'. This script code extracts the
libraries into a directory then creates a new library containing all the
extracted object files.
Regards
More information about the rtems-users
