Does RTEMS support PXA320?
Sang Won Yoo
swyoo111 at gmail.com
Wed Aug 1 12:41:10 CDT 2007
Thank you very much, Joel.
It must be helpful to make a decision for us.
-Sam (Sangwon)
On 8/1/07, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> Sang Won Yoo wrote:
> > Thanks for the response.
> > I have tried to look for the thread, but I haven't.
> > Can anyone point me to the thread?
> The links I got with Google: "xscale site:rtems.org"
> didn't turn up anything useful either. Just people asking.
> This would require a new BSP but the existing ARM
> port itself should be sufficient. There is a Guide to
> Writing BSPs and Device Drivers. In general terms,
> you start at "start.S" and work through until you
> have hello, then ticker, then network demos running. :-D
> I would recommend finding a decent simulator for the
> CPU and using it for some of the development. Skyeye
> probably supports the CPU model you are interested in.
> If you want help, OAR and others are available to
> write BSPs for you. There is also a class August 21-24
> here in Huntsville. A significant part of the class is
> on BSPs.
> --joel
> > Thanks in advance.
> > SW Yoo
> > On 7/31/07, *Amalaye Oyake* <amalaye.oyake at jpl.nasa.gov
> > <mailto:amalaye.oyake at jpl.nasa.gov>> wrote:
> > This is one of the newer XScale processors (an ARM variant). RTEMS
> > people -
> > What is the status of the RTEMS XScale BSP? Can one simply use the
> > ARM BSP?
> > Can someone please list the general issues in getting an XScale BSP
> > developed. I think there was a thread about this a while back if I
> > remember.
> > Sincerely,
> > AO
> > ________________________________________
> > From: rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
> > <mailto:jpl.nasa.gov at rtems.org>
> > [mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
> > <mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org>]
> > On Behalf
> > Of Sang Won Yoo
> > Sent: Tuesday, July 31, 2007 10:24 AM
> > To: rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> > Subject: Does RTEMS support PXA320?
> > Hello RTEMS gurus,
> > I am new to this list to start with RTEMS for my new project.
> > The CPU on proejct has been determined to use PXA320. But not yet
> > determined
> > for RTOS.
> > After Ireviewed several RTOS, RTEMS is good enough for the
> > project. But I
> > am wondering if RTEMS
> > supports the CPU, PXA320 now. If so, please let me know where I
> > can start
> > with RTEMS.
> > Thanks for your attention.
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://www.rtems.org/pipermail/rtems-users/attachments/20070801/bdfb265f/attachment.html>
More information about the rtems-users
