more problems building RTEMS 4.6.99.3 powerpc on cygwin
Robert S. Grimes
rsg at alum.mit.edu
Thu Dec 28 12:33:26 CST 2006
I have exactly the same problem, except my BSP is using the
old-exceptions; just substitute "old" for "new", and same thing. I
thought it was peculiar to a set of patches I've been working with for a
Virtex part, though, so I didn't mention it on the Wiki. I spent some
time looking for it, but wasn't able to find it. I was hoping to
resolve it eventually...
I have been working around it in the meantime. What seems to be
happening is the the cpu_asm.o file is indeed being built, but it is
either built, or looked for, in the wrong location. My error and
workaround is here:
if powerpc-rtems-gcc --pipe -B../../../../.././lib/
-B../../../../.././gen405/lib/ -specs bsp_specs -qrtems -DPACKAGE_NA
ME=\"rtems-c-src-lib-libcpu-powerpc\"
-DPACKAGE_TARNAME=\"rtems-c-src-lib-libcpu-powerpc\"
-DPACKAGE_VERSION=\"4.6.99.3\
" -DPACKAGE_STRING=\"rtems-c-src-lib-libcpu-powerpc\ 4.6.99.3\"
-DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\" -I. -I../..
/../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc -isystem
../../../../.././gen405/lib/include -I../../../../../.
./../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions -Wall
-mcpu=403 -D_OLD_EXCEPTIONS -Dppc405 -O4 -fno-keep-in
line-functions -g -MT
old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o -MD -MP -MF
"old-exceptions/.deps/old_exceptions
_rtems_cpu_rel-cpu.Tpo" -c -o
old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o `test -f
'old-exceptions/cpu.c' || echo
'../../../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/'`old-exceptions/cpu.c;
then mv -f
"old-exceptions/.deps/old_exceptions_rtems_cpu_rel-cpu.Tpo"
l-cpu.Po"; else rm -f
"old-exceptions/.deps/old_exceptions_rtems_cpu_rel-cpu.Tpo"; exit 1; fi
-B../../../../.././gen405/lib/ -specs bsp_specs -qrtems -isystem ../../
../../.././gen405/lib/include -DASM -mcpu=403 -D_OLD_EXCEPTIONS
-Dppc405 -O4 -fno-keep-inline-functions -g -c ../../..
/../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions/cpu_asm.S
-B../../../../.././gen405/lib/ -specs bsp_specs -qrtems -Wall -mcpu=403
-D_OLD_EXCEPTIONS -Dppc405 -O4 -fno-keep-inline-functions -g -o
old-exceptions/rtems-cpu.rel -qnolinkcmds -nostdlib -
Wl,-r old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o
old-exceptions/cpu_asm.o
powerpc-rtems-gcc: old-exceptions/cpu_asm.o: No such file or directory
make[5]: *** [old-exceptions/rtems-cpu.rel] Error 1
make[5]: Leaving directory
`/cygdrive/c/Home/ll/etill/rtems-4.6.99.3/tools/b-rtems/powerpc-rtems/c/gen405/lib/libcpu/pow
erpc'
$ cp -i powerpc-rtems/c/gen405/lib/libcpu/powerpc/cpu_asm.o
powerpc-rtems/c/gen405/lib/libcpu/powerpc/old-exceptions/
$ make all
After this, I get two more similar errors, and I assume it's the same
situation, so I work around it the same way.
ppc403/vectors.rel -qnolinkcmds -nostdlib -Wl,-r ppc4
03/vectors/vectors.o ppc403/vectors/align_h.o
powerpc-rtems-gcc: ppc403/vectors/vectors.o: No such file or directory
powerpc-rtems-gcc: ppc403/vectors/align_h.o: No such file or directory
make[5]: *** [ppc403/vectors.rel] Error 1
erpc'
$ cp -i powerpc-rtems/c/gen405/lib/libcpu/powerpc/vectors.o
powerpc-rtems/c/gen405/lib/libcpu/powerpc/ppc403/vectors/
$ cp -i powerpc-rtems/c/gen405/lib/libcpu/powerpc/align_h.o
$ make all
This gets me done. As you stated earlier, I too am "far from being an
expert on the configure.ac and makefile.am stuff", so I'm not sure how
to resolve it, but for now the workaround is good enough; after all, my
real job is what I am developing with RTEMS... :-P
That being said, I'm sure interested in fixing it properly!
-Bob
avy st wrote:
> Hello All,
> I'm trying to build the RTEMS toolset and RTEMS 4.6.99.3 for powerpc,
> hosted on cygwin, and supporting Ada. I followed pretty much the
> instructions given on
> http://www.rtems.com/wiki/index.php/BuildingUnderCygwin (with the
> required modifications needed for Ada building), and got more problem
> when building RTEMS itself which blows with the following message:
> make[5]: Entering directory
> `/cygdrive/d/BuildGccCygwin/powerpc-rtems-4.7-tools/rtems-4.6.99.3/powerpc-rtems/c/ss555/lib/libcpu/powerpc'
> -B../../../../.././ss555/lib/ -specs bsp_specs -qrtems
> -DPACKAGE_NAME=\"rtems-c-src-lib-libcpu-powerpc\"
> -DPACKAGE_VERSION=\"4.6.99.3\"
> <mailto:rtems-bugs at rtems.com%5C>" -I.
> -I../../../../../../../../source/rtems-4.6.99.3/c/src/lib/libcpu/powerpc
> -isystem ../../../../.././ss555/lib/include -Wall -mcpu=505
> -Dmpc555 -Dss555 -O4 -fno-keep-inline-functions -MT
> new-exceptions/new_exceptions_rtems_cpu_rel-cpu.o -MD -MP -MF
> "new-exceptions/.deps/new_exceptions_rtems_cpu_rel-cpu.Tpo" -c -o
> new-exceptions/new_exceptions_rtems_cpu_rel-cpu.o `test -f
> 'new-exceptions/cpu.c' || echo
> '../../../../../../../../source/rtems-4.6.99.3/c/src/lib/libcpu/powerpc/'`new-exceptions/cpu.c;
> then mv -f
> "new-exceptions/.deps/new_exceptions_rtems_cpu_rel-cpu.Po"; else
> rm -f "new-exceptions/.deps/new_exceptions_rtems_cpu_rel-cpu.Tpo";
> exit 1; fi
> -B../../../../.././ss555/lib/ -specs bsp_specs -qrtems -isystem
> ../../../../.././ss555/lib/include -DASM -mcpu=505 -Dmpc555
> -Dss555 -O4 -fno-keep-inline-functions -c
> ../../../../../../../../source/rtems-4.6.99.3/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
> -B../../../../.././ss555/lib/ -specs bsp_specs -qrtems -Wall
> -mcpu=505 -Dmpc555 -Dss555 -O4 -fno-keep-inline-functions -o
> new-exceptions/rtems-cpu.rel -qnolinkcmds -nostdlib -Wl,-r
> new-exceptions/cpu_asm.o
> powerpc-rtems-gcc: new-exceptions/cpu_asm.o: No such file or directory
> make[5]: *** [new-exceptions/rtems-cpu.rel] Error 1
> Any Ideas?
> Thanks everybody
> Avy Strominger
> astrominger at yahoo.com <mailto:astrominger at yahoo.com>
> rtems-users mailing list
> rtems-users at rtems.com
More information about the rtems-users
