Xilinx IP core drivers for RTEMS- diff attached - BUILD SUCCESS!
Robert S. Grimes
rsg at alum.mit.edu
Thu Dec 21 13:32:00 CST 2006
Hi Greg,
Okay, no it is okay for you to be really annoyed with me. It turns out
that I had subconsciously convinced myself that bootstrap was not necessary!
Still, there are a few minor glitches, one of which you already know
about. This is the procedure I followed that finally worked.
Step 1. Unpack
$ cd tools
$ tar xjf ../archive/rtems-4.6.99.3
Step 2. Apply your/Keith's patch
$ cd rtems-4.6.99.3
$ cat ../../archive/proposed-gen405.diff | patch -p0
Step 3. Run bootstrap in rtems-4.6.99.3 source tree
$ ./bootstrap
Step 4. Configure
$ cd ../b-rtems
$ ../rtems-4.6.99.3/configure --target=powerpc-rtems --enable-posix
--enable-networking --enable-cxx --enable-rtemsbsp="gen405"
--prefix=/usr/rtems/4.6.99.3
Step 5. First build attempt
make all #- fails due to missing xilemac.h file - old problem
Step 6. Second build attempt
cp ../rtems-4.6.99.3/c/src/libchip/network/xilemac.h
powerpc-rtems/gen405/lib/include/libchip
make all #-fails with this message
if powerpc-rtems-gcc --pipe -B../../../../.././lib/
-B../../../../.././gen405/lib/ -specs bsp_specs -qrtems -DPACKAGE_NA
ME=\"rtems-c-src-lib-libcpu-powerpc\"
-DPACKAGE_TARNAME=\"rtems-c-src-lib-libcpu-powerpc\"
-DPACKAGE_VERSION=\"4.6.99.3\
" -DPACKAGE_STRING=\"rtems-c-src-lib-libcpu-powerpc\ 4.6.99.3\"
-DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\" -I. -I../..
/../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc -isystem
../../../../.././gen405/lib/include -I../../../../../.
./../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions -Wall
-mcpu=403 -D_OLD_EXCEPTIONS -Dppc405 -O4 -fno-keep-in
line-functions -g -MT
old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o -MD -MP -MF
"old-exceptions/.deps/old_exceptions
_rtems_cpu_rel-cpu.Tpo" -c -o
old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o `test -f
'old-exceptions/cpu.c' || echo
'../../../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/'`old-exceptions/cpu.c;
then mv -f
"old-exceptions/.deps/old_exceptions_rtems_cpu_rel-cpu.Tpo"
l-cpu.Po"; else rm -f
"old-exceptions/.deps/old_exceptions_rtems_cpu_rel-cpu.Tpo"; exit 1; fi
-B../../../../.././gen405/lib/ -specs bsp_specs -qrtems -isystem ../../
../../.././gen405/lib/include -DASM -mcpu=403 -D_OLD_EXCEPTIONS
-Dppc405 -O4 -fno-keep-inline-functions -g -c ../../..
/../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions/cpu_asm.S
-B../../../../.././gen405/lib/ -specs bsp_specs -qrtems -Wall -mcpu=403
-D_OLD_EXCEPTIONS -Dppc405 -O4 -fno-keep-inline-functions -g -o
old-exceptions/rtems-cpu.rel -qnolinkcmds -nostdlib -
Wl,-r old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o
old-exceptions/cpu_asm.o
powerpc-rtems-gcc: old-exceptions/cpu_asm.o: No such file or directory
make[5]: *** [old-exceptions/rtems-cpu.rel] Error 1
make[5]: Leaving directory
`/cygdrive/c/Home/ll/etill/rtems-4.6.99.3/tools/b-rtems/powerpc-rtems/c/gen405/lib/libcpu/powerpc'
Step 7. Third build attempt
$ cp powerpc-rtems/c/gen405/lib/libcpu/powerpc/cpu_asm.o
powerpc-rtems/c/gen405/lib/libcpu/powerpc/old-exceptions/
$ make all #- fails with this message
ppc403/vectors.rel -qnolinkcmds -nostdlib -Wl,-r ppc4
03/vectors/vectors.o ppc403/vectors/align_h.o
powerpc-rtems-gcc: ppc403/vectors/vectors.o: No such file or directory
powerpc-rtems-gcc: ppc403/vectors/align_h.o: No such file or directory
make[5]: *** [ppc403/vectors.rel] Error 1
Step 8. Final build attempt
$ cp -i powerpc-rtems/c/gen405/lib/libcpu/powerpc/vectors.o
powerpc-rtems/c/gen405/lib/libcpu/powerpc/ppc403/vectors/
$ cp -i powerpc-rtems/c/gen405/lib/libcpu/powerpc/align_h.o
$ make all
$ make install
Completes Successfully!!! I have a meeting now, so I can't actually
test anything yet, but that's next!
So it seems you still have some issues with the bootstrap/configure
process. Sadly, I have absolutely no idea where - those tools are
completely foreign to me...
Sorry 'bout my mis-steps!
-Bob
Robert S. Grimes wrote:
> Oh, the final error is in the
> <BUILDROOT>/powerpc-rtems/c/gen405/testsuites/samples/hello example
> program build.
> Also, in the "First Attempt", the path should be
> <BUILDROOT>/powerpc-rtems/gen405/lib/include/libchip
>> Okay, I've got major egg on my face! The "xilemac.c and xilemac.h are
>> identical" comment is false! Red Herring! My screw-up!
>> This morning, I decided to start over, and see if I can prove or
>> disprove it. So I started with a clean un-tar, applied the patch, then
>> looked at xilemac.h - lo and behold, it is now a real header file! I
>> still can't quite get it to build, though. Here is what I've found so
>> far...
>> First Attempt:
>> make all
>> - fails during compile due to missing xilemac.h file
>> Fix: cp <SOURCEROOT>/c/src/libchip/network/xilemac.h
>> <BUILDROOT>/gen405/lib/include/libchip
>> Second Attempt:
>> make all
>> - fails during compile due to missing opbintctrl.h
>> Fix: cp
>> <SOURCEROOT>/c/src/lib/libbsp/powerpc/gen405/include/opbintctrl.h
>> Third Attempt
>> make all
>> - fails during link due to error:
>> gen405/lib/librtemsbsp.a(startup.rel): In function `bsp_predriver_hook':
>> c/src/lib/libbsp/powerpc/gen405/startup/bspstart.c:107: undefined
>> reference to `opb_intc_init'
>> I haven't yet resolved the third problem, but I have narrowed it down a
>> wee bit. Seems
>> <ROOT>/c/src/lib/libbsp/powerpc/gen405/opbintctrl/opbintctrl.c is not
>> being compiled or included in the link.
>> I'll keep you informed, and once again, SORRY!!!
>> -Bob
>>> Wow! I don't know what happened, if it was the atuoconf/automake stuff
>>> or not, but I just realized in the source tree after patching, the files
>>> xilemac.c and xilemac.h are identical; specifically, they both contain
>>> what should be the .c contents! This explains why there is the #include
>>> directive! It may be my error, and I have to leave now so I can't
>>> confirm one way or the other, but my guess is that you might be sending
>>> xilemac.c to both the .c and .h files during configure. Of course, it
>>> may be I don't know what I'm talking about...
>>> More tomorrow...
>>> -Bob
>>> gregory.menke at gsfc.nasa.gov wrote:
>>>> Hi Bob,
>>>> There is only one xilemac.h, and it should be in libchip.
>>>> gen405/include/bsp.h is supposed to include libchip/xilemac.h, so it can
>>>> obtain driver definitions. I just checked the diff and it looks like I
>>>> screwed it up- I see the extra include as you say, but it does not exist
>>>> in my source. Beats me how I messed it up, but there you go...
>>>> With the gen405 in its present setup, I think xilemac would be better
>>>> located in the bsp than in libchip. If/when a virtex bsp shows up, then
>>>> xilemac could be copied into libchip- leaving the current version in
>>>> gen405 sort of like how the pc386 bsp has its own network drivers.
>>>> If/when gen405 moves to new_exceptions then maybe it could abandon its
>>>> internal xilemac in favor of the libchip version.
>>>> Given the above, I'd like to regenerate the diff with xilemac moved back
>>>> into the gen405 bsp, which makes sense given the old_exceptions and the
>>>> assumptions about the driver that the bsp makes. I'll try to get a new
>>>> patch out in a day or so, and please accept my apologies for the broken
>>>> diffs...
>>>> Regards,
>>>> Greg
>>>> Robert S. Grimes writes:
>>>> > Yes,
>>>> > It looks like $SOURCEDIR/c/src/libchip/network/xilemac.h (only xilemac.h
>>>> > I was able to find in source tree) is not making it into
>>>> > $BUILDIDR/powerpc-rtems/gen405/lib/include/libchip.
>>>> > I attempted to fix that by copying the file. However, when I did that,
>>>> > I got a problem about infinite include nesting; seems the file was
>>>> > including itself? Perhaps I am confused, but there is an include
>>>> > directive in xilemac.h like this
>>>> > #include <libchip/xilemac.h>
>>>> > If I comment that out, the infinite nesting problem goes away, but is
>>>> > replaced by these
>>>> > In file included from ../../../../.././gen405/lib/include/bsp.h:73,
>>>> > from
>>>> > ../../../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions/cpu.c:31:
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:234: error:
>>>> > 'NUM_XILEMAC_UNITS' undeclared here (not in a function)
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h: In function
>>>> > 'xilFifoRead32':
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:270: error:
>>>> > 'XEM_PFIFO_RXDATA_OFFSET' undeclared (first use in this function)
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:270: error: (Each
>>>> > undeclared identifier is reported only once
>>>> > ./../../../.././gen405/lib/include/libchip/xilemac.h:270: error: for
>>>> > each function it appears in.)
>>>> > 'xilFifoWrite32':
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:309: error:
>>>> > 'XEM_PFIFO_TXREG_OFFSET' undeclared (first use in this function)
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:318: error:
>>>> > 'DRIVER_PREFIX' undeclared (first use in this function)
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:327: error:
>>>> > 'XEM_PFIFO_TXDATA_OFFSET' undeclared (first use in this function)
>>>> > 'xilGetWrFifo32VacancyBytes':
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:363: error:
>>>> > 'xilFifoRead64':
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:385: error:
>>>> > 'xilFifoWrite64':
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:440: error:
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:445: error:
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:452: error:
>>>> > 'xilGetWrFifo64VacancyBytes':
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:507: error:
>>>> > 'xilGetWrFifoVacancyBytes':
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:533: error:
>>>> > 'xilEmacStop':
>>>> > ./../../../.././gen405/lib/include/libchip/xilemac.h:548: error:
>>>> > dereferencing pointer to incomplete type
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:551: error:
>>>> > 'XEM_ECR_OFFSET' undeclared (first use in this function)
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:555: error:
>>>> > ../../../../.././gen405/lib/include/libchip/xilemac.h:559: error:
>>>> > and so on, especially the deref pointer errors.
>>>> > Seems something else is missing wrt the Xilinx definitions...
>>>> > Thanks,
>>>> > -Bob
>>>> > > Hi Robert,
>>>> > > Its likely something missing from the patch since I had a strip out a
>>>> > > lot of test things from the diff. I'll have a look at get back to you.
>>>> > > OTOH I continue to have problems with automake/autoconf occasionally
>>>> > > generating makefiles that need editing because its unclear which
>>>> > > versions work and which won't and RTEMS stays so close to the
>>>> > > toolchain's bleeding edge that its hard to tell. So there is some
>>>> > > possiblity that automake/autoconf issues could be causing trouble.
>>>> > > Greg
>>>> > > > Hi Greg,
>>>> > > > I attempt to build using your patches on a clean install of 4.6.99.3,
>>>> > > > and I get this error:
>>>> > > > Making all in powerpc
>>>> > > > make[5]: Entering directory
>>>> > > > `/cygdrive/c/Home/ll/etill/rtems-4.6.99.3/tools/b-rtems-4.6.99.3/powerpc-rtems/c/gen405/lib/
>>>> > > > libcpu/powerpc'
>>>> > > > ./../../../../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc -isystem
>>>> > > > ../../rtems-4.6.99.3/c/src/lib/libcpu/powerpc/old-exceptions -Wall
>>>> > > > nline-functions -g -MT
>>>> > > > s_rtems_cpu_rel-cpu.Tpo" -c -o
>>>> > > > then mv -f
>>>> > > > ../../../../.././gen405/lib/include/bsp.h:73:29: error:
>>>> > > > libchip/xilemac.h: No such file or directory
>>>> > > > make[5]: *** [old-exceptions/old_exceptions_rtems_cpu_rel-cpu.o] Error 1
>>>> > > > `/cygdrive/c/Home/ll/etill/rtems-4.6.99.3/tools/b-rtems-4.6.99.3/powerpc-rtems/c/gen405/lib/l
>>>> > > > ibcpu/powerpc'
>>>> > > > The "xilemac.h" file certainly does exist! It seems there's an include
>>>> > > > path problem. I'm going to try and track it down, but I thought you might:
>>>> > > > - know what I did wrong (if it's my mistake), or
>>>> > > > - want to know (if it's a patch problem).
>>>> > > > I will let you know what I find on my end.
>>>> > > > Thanks!
>>>> > > > -Bob
>>>> > > > > Hi,
>>>> > > > > I finally got back to some long-needed config management on the gen405
>>>> > > > > bsp. I assembled the diffs against 4.6.99.3, the file is attached for
>>>> > > > > review.
>>>> > > > > I hesitate to just check them in as some of the changes related to
>>>> > > > > uarts, fpu and memory map are highly idiosyncratic and I don't want to
>>>> > > > > mess up other people's work. I think a compromise patch might make the
>>>> > > > > most sense, where I set up a diff that preserves the general character
>>>> > > > > of the bsp; base addresses, etc.. but gets in the updated drivers.
>>>> > > > > Our bsp was peculiar in that the 405 units have 4 uarts and no fpu at
>>>> > > > > all, meaning, the entire toolchain has to be compiled with -msoft-float
>>>> > > > > to ensure nothing at all in newlib or above uses fp registers- the
>>>> > > > > va_args are problematic since the ppc ABI allows fpu registers to be
>>>> > > > > used when handing variable arguments. I think it is this issue that
>>>> > > > > generally forces all PPC tasks to be floating point- its quite an
>>>> > > > > annoying architectural property.
>>>> > > > > So I'd like to propose that folks interested in the Virtex 4 gen405 bsp
>>>> > > > > family have a look at the diffs and respond with issues & changes and
>>>> > > > > hopefully I can commit something that doesn't cause too much trouble.
>>>> > > > > If folks' email systems won't pass the attachment, then please email me
>>>> > > > > and I'll resend directly.
>>>> > > > > Thanks,
>>>> > > > > Greg
>>>> > > > > _______________________________________________
>>>> > > > > rtems-users mailing list
>>>> > > > > rtems-users at rtems.com
>>>> > > > > http://rtems.rtems.org/mailman/listinfo/rtems-users
More information about the rtems-users
