Where I can find a simple posix RTEMS example + Makefile ?
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Dec 7 16:00:32 CST 2006
Jiyang Kang wrote:
> I got the examples. Thank you very much!
No problem. If you have any questions or problems with them, please
feel free to ask.
If you have any other suggestions for additional examples, they are
welcomed.
FWIW a number of them are contorted and possibly questionable ways to blink
an LED at a particular rate. There are macros to change to get a real
LED blinking
on real hardware. Otherwise, it will just print "LED ON" or "LED OFF".
--joel
> -Jiyang
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Thursday, December 07, 2006 4:33 PM
> To: Jiyang Kang
> Subject: Re: Where I can find a simple posix RTEMS example + Makefile ?
> Jiyang Kang wrote:
>> Hi Joel,
>> My name is Jiyang Kang, and this is a question regarding this RTEMS
> thread:
>> http://www.rtems.com/ml/rtems-users/2006/february/msg00040.html
>> I searched for the 'class-examples CVS module' but could not figure
>> out what it means.
>> Can you point me the exact path of it?
> |cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS login|
> <no password so press return
> |cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS co -P class-examples
> And you will have the class examples in the current source.
> You probably want to look at posix_*.
> --joel
>> Thanks in advance.
>> Jiyang Kang
>> Visiting Scholar / Ph.D.
>> Computer Science
>> Division of Engineering and Applied Sciences Harvard University
>> Tel : 617-913-7062
>> E-mail: jkang at eecs.harvard.edu
More information about the rtems-users
