Problem report: Struct aliasing problem causes Thread_Ready_Chain corruption in 4.6.99.3
Till Straumann
strauman at slac.stanford.edu
Mon Dec 4 20:15:55 CST 2006
Aaron J. Grier wrote:
> On Mon, Dec 04, 2006 at 03:14:49PM -0800, Till Straumann wrote:
>> I believe you would have to declare a union
>> union clumsy_union {
>> Pbuf raw_buffer;
>> struct udp_packet packet;
>> } xxx;
> unions have enough space to hold all the member datatypes, but is there
> anything in the standard that says that the members actually have to
> occupy the same memory space, or how they are actually overlayed?
> K&R says "It is the responsibility of the programmer to keep track of
> what type is currently stored in a union; the results are machine
> dependent if something is stored as one type and extracted as another."
> what does c99 say?
There is a useful passage (doesn't apply exactly to my example
[punning a char stream into another object] though - for that
kind of operation we need to make assumptions about the
representation of objects on our machine. But hey, we're
implementing an OS here so that is not unreasonable):
Anyways - here's what the standard says about unions
(6.5.2.3 #5):
"One special guarantee is made in order to simplify the use of
unions: if a union contains several structures that share
a common initial sequence, and if the union object currently
contains one of these structures, it is permitted to inspect the
common initial part of any of them anywhere that a declaration
of the complete type of the union is visible..."
I.e., I can say
union packet {
struct { struct ip_header iph; char data[] } ip_packet;
struct { struct ip_header iph; struct udp_header udph; char data[]; }
udp_packet;
union packet *p;
if ( p->ip_packet.iph.proto == 17 )
/* access p->udp_packet here */
>> The problem with this approach is that you don't know upfront that
>> your data is a udp packet.
>> So you'd need unions of all possible variants at each layer of a
>> protocol stack.
> ignoring the union overlay properties mentioned above, couldn't (char *)
> be used as the lowest common denominator?
sorry - I don't understand. Could you explain?
T.
> (alignment issues
> notwithstanding.)
More information about the rtems-users
