Results for 4.6.1 20110329 (prerelease) (GCC) testsuite on sparc-unknown-rtems4.11
Joel Sherrill
joel at rtems.org
Sun Apr 3 14:55:39 CDT 2011
Target is sparc-unknown-rtems4.11
Host is x86_64-unknown-linux-gnu
=== gcc tests ===
Running target rtems-sparc-sis
FAIL: gcc.c-torture/compile/limits-exprparen.c -O0 (internal compiler error)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O0 (test for excess errors)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O1 (internal compiler error)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O1 (test for excess errors)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O2 (internal compiler error)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O2 (test for excess errors)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O3 -fomit-frame-pointer (internal compiler error)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O3 -fomit-frame-pointer (test for excess errors)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O3 -g (internal compiler error)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O3 -g (test for excess errors)
FAIL: gcc.c-torture/compile/limits-exprparen.c -Os (internal compiler error)
FAIL: gcc.c-torture/compile/limits-exprparen.c -Os (test for excess errors)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O2 -flto -flto-partition=none (internal compiler error)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O2 -flto -flto-partition=none (test for excess errors)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O2 -flto (internal compiler error)
FAIL: gcc.c-torture/compile/limits-exprparen.c -O2 -flto (test for excess errors)
FAIL: gcc.c-torture/execute/builtins/20010124-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/20010124-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/fprintf.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/fprintf.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/fputs.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/fputs.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/memcpy-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/memcpy-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/memmove-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/memmove-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/memops-asm.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/memops-asm.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/mempcpy-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/mempcpy-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/memset-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/memset-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/memset.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/memset.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/pr22237.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/pr22237.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/pr23484-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/pr23484-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/printf.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/printf.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/snprintf-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/snprintf-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/sprintf-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/sprintf-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/sprintf.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/sprintf.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/stpcpy-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/stpcpy-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/strcat-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/strcat-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/strcmp.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/strcmp.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/strcpy-2.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/strcpy-2.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/strcpy-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/strcpy-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/strcpy.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/strcpy.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/strlen-2.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/strlen-2.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/strlen-3.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/strlen-3.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/strlen.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/strlen.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/strncat-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/strncat-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/strncpy-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/strncpy-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/strncpy.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/strncpy.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/vsnprintf-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/vsnprintf-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/builtins/vsprintf-chk.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/builtins/vsprintf-chk.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/20020406-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/20020406-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/20021120-3.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/20021120-3.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/20070201-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/20070201-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/20101011-1.c execution, -O0
FAIL: gcc.c-torture/execute/20101011-1.c execution, -O1
FAIL: gcc.c-torture/execute/20101011-1.c execution, -O2
FAIL: gcc.c-torture/execute/20101011-1.c execution, -O3 -fomit-frame-pointer
FAIL: gcc.c-torture/execute/20101011-1.c execution, -O3 -g
FAIL: gcc.c-torture/execute/20101011-1.c execution, -Os
FAIL: gcc.c-torture/execute/20101011-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/20101013-1.c execution, -O2
FAIL: gcc.c-torture/execute/20101013-1.c execution, -O3 -fomit-frame-pointer
FAIL: gcc.c-torture/execute/20101013-1.c execution, -O3 -fomit-frame-pointer -funroll-loops
FAIL: gcc.c-torture/execute/20101013-1.c execution, -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions
FAIL: gcc.c-torture/execute/20101013-1.c execution, -O3 -g
FAIL: gcc.c-torture/execute/20101013-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/920501-8.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/920501-8.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/920501-9.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/920501-9.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/920726-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/920726-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/930513-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/930513-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/941014-2.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/941014-2.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/980605-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/980605-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/980709-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/980709-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/built-in-setjmp.c execution, -O0
FAIL: gcc.c-torture/execute/built-in-setjmp.c execution, -O1
FAIL: gcc.c-torture/execute/built-in-setjmp.c execution, -O2
FAIL: gcc.c-torture/execute/built-in-setjmp.c execution, -O3 -fomit-frame-pointer
FAIL: gcc.c-torture/execute/built-in-setjmp.c execution, -O3 -fomit-frame-pointer -funroll-loops
FAIL: gcc.c-torture/execute/built-in-setjmp.c execution, -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions
FAIL: gcc.c-torture/execute/built-in-setjmp.c execution, -O3 -g
FAIL: gcc.c-torture/execute/built-in-setjmp.c execution, -Os
FAIL: gcc.c-torture/execute/built-in-setjmp.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/fprintf-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/fprintf-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/fprintf-chk-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/fprintf-chk-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/printf-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/printf-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/printf-chk-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/printf-chk-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/struct-ret-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/struct-ret-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/va-arg-21.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/va-arg-21.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/va-arg-24.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/va-arg-24.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/vfprintf-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/vfprintf-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/vfprintf-chk-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/vfprintf-chk-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/vprintf-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/vprintf-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/vprintf-chk-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/vprintf-chk-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/ieee/20041213-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/ieee/20041213-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/ieee/920810-1.c compilation, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.c-torture/execute/ieee/920810-1.c execution, -O2 -flto -flto-partition=none
FAIL: gcc.c-torture/execute/ieee/compare-fp-4.c execution, -O0
FAIL: gcc.c-torture/execute/ieee/fp-cmp-1.c execution, -O0
FAIL: gcc.c-torture/execute/ieee/fp-cmp-1.c execution, -O1
FAIL: gcc.c-torture/execute/ieee/fp-cmp-1.c execution, -O2
FAIL: gcc.c-torture/execute/ieee/fp-cmp-1.c execution, -O3 -fomit-frame-pointer
FAIL: gcc.c-torture/execute/ieee/fp-cmp-1.c execution, -O3 -fomit-frame-pointer -funroll-loops
FAIL: gcc.c-torture/execute/ieee/fp-cmp-1.c execution, -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions
FAIL: gcc.c-torture/execute/ieee/fp-cmp-1.c execution, -O3 -g
FAIL: gcc.c-torture/execute/ieee/fp-cmp-1.c execution, -Os
FAIL: gcc.c-torture/execute/ieee/fp-cmp-2.c execution, -O0
FAIL: gcc.c-torture/execute/ieee/fp-cmp-2.c execution, -O1
FAIL: gcc.c-torture/execute/ieee/fp-cmp-2.c execution, -O2
FAIL: gcc.c-torture/execute/ieee/fp-cmp-2.c execution, -O3 -fomit-frame-pointer
FAIL: gcc.c-torture/execute/ieee/fp-cmp-2.c execution, -O3 -fomit-frame-pointer -funroll-loops
FAIL: gcc.c-torture/execute/ieee/fp-cmp-2.c execution, -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions
FAIL: gcc.c-torture/execute/ieee/fp-cmp-2.c execution, -O3 -g
FAIL: gcc.c-torture/execute/ieee/fp-cmp-2.c execution, -Os
FAIL: gcc.c-torture/execute/ieee/fp-cmp-3.c execution, -O0
FAIL: gcc.c-torture/execute/ieee/fp-cmp-3.c execution, -O1
FAIL: gcc.c-torture/execute/ieee/fp-cmp-3.c execution, -O2
FAIL: gcc.c-torture/execute/ieee/fp-cmp-3.c execution, -O3 -fomit-frame-pointer
FAIL: gcc.c-torture/execute/ieee/fp-cmp-3.c execution, -O3 -fomit-frame-pointer -funroll-loops
FAIL: gcc.c-torture/execute/ieee/fp-cmp-3.c execution, -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions
FAIL: gcc.c-torture/execute/ieee/fp-cmp-3.c execution, -O3 -g
FAIL: gcc.c-torture/execute/ieee/fp-cmp-3.c execution, -Os
FAIL: gcc.c-torture/execute/ieee/fp-cmp-6.c execution, -O0
FAIL: gcc.dg/20010912-1.c execution test
FAIL: gcc.dg/20021018-1.c execution test
FAIL: gcc.dg/20050321-2.c (test for excess errors)
FAIL: gcc.dg/980523-1.c execution test
FAIL: gcc.dg/initpri1.c execution test
FAIL: gcc.dg/initpri3.c execution test
FAIL: gcc.dg/pr27758.c execution test
FAIL: gcc.dg/pr28796-2.c execution test
FAIL: gcc.dg/pr34457-1.c (test for excess errors)
FAIL: gcc.dg/graphite/run-id-1.c execution test
FAIL: gcc.dg/graphite/interchange-0.c execution test
FAIL: gcc.dg/graphite/interchange-1.c execution test
FAIL: gcc.dg/graphite/interchange-10.c execution test
FAIL: gcc.dg/graphite/interchange-11.c execution test
FAIL: gcc.dg/graphite/interchange-15.c execution test
FAIL: gcc.dg/graphite/interchange-2.c execution test
FAIL: gcc.dg/graphite/interchange-3.c execution test
FAIL: gcc.dg/graphite/interchange-4.c execution test
FAIL: gcc.dg/graphite/interchange-7.c execution test
FAIL: gcc.dg/graphite/interchange-mvt.c execution test
FAIL: gcc.dg/graphite/block-3.c execution test
FAIL: gcc.dg/graphite/block-4.c execution test
FAIL: gcc.dg/graphite/pr43012.c execution test
FAIL: gcc.dg/graphite/pr46185.c execution test
FAIL: gcc.dg/lto/20081024 c_lto_20081024_0.o-c_lto_20081024_0.o link, -O0 -flto -flto-partition=none
UNRESOLVED: gcc.dg/lto/20081024 c_lto_20081024_0.o-c_lto_20081024_0.o execute -O0 -flto -flto-partition=none
FAIL: gcc.dg/lto/20081024 c_lto_20081024_0.o-c_lto_20081024_0.o link, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.dg/lto/20081024 c_lto_20081024_0.o-c_lto_20081024_0.o execute -O2 -flto -flto-partition=none
FAIL: gcc.dg/lto/20081024 c_lto_20081024_0.o-c_lto_20081024_0.o link, -O0 -flto -flto-partition=1to1
UNRESOLVED: gcc.dg/lto/20081024 c_lto_20081024_0.o-c_lto_20081024_0.o execute -O0 -flto -flto-partition=1to1
FAIL: gcc.dg/lto/20081024 c_lto_20081024_0.o-c_lto_20081024_0.o link, -O2 -flto -flto-partition=1to1
UNRESOLVED: gcc.dg/lto/20081024 c_lto_20081024_0.o-c_lto_20081024_0.o execute -O2 -flto -flto-partition=1to1
FAIL: gcc.dg/lto/20090210 c_lto_20090210_0.o-c_lto_20090210_1.o execute -O0 -flto -flto-partition=none
FAIL: gcc.dg/lto/20090210 c_lto_20090210_0.o-c_lto_20090210_1.o execute -O2 -flto -flto-partition=none
FAIL: gcc.dg/lto/20090210 c_lto_20090210_0.o-c_lto_20090210_1.o execute -O0 -flto -flto-partition=1to1
FAIL: gcc.dg/lto/20090210 c_lto_20090210_0.o-c_lto_20090210_1.o execute -O2 -flto -flto-partition=1to1
FAIL: gcc.dg/lto/20090213 c_lto_20090213_0.o-c_lto_20090213_1.o link, -O0 -flto -flto-partition=none
UNRESOLVED: gcc.dg/lto/20090213 c_lto_20090213_0.o-c_lto_20090213_1.o execute -O0 -flto -flto-partition=none
FAIL: gcc.dg/lto/20090213 c_lto_20090213_0.o-c_lto_20090213_1.o link, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.dg/lto/20090213 c_lto_20090213_0.o-c_lto_20090213_1.o execute -O2 -flto -flto-partition=none
FAIL: gcc.dg/lto/20090213 c_lto_20090213_0.o-c_lto_20090213_1.o link, -O0 -flto -flto-partition=1to1
UNRESOLVED: gcc.dg/lto/20090213 c_lto_20090213_0.o-c_lto_20090213_1.o execute -O0 -flto -flto-partition=1to1
FAIL: gcc.dg/lto/20090213 c_lto_20090213_0.o-c_lto_20090213_1.o link, -O2 -flto -flto-partition=1to1
UNRESOLVED: gcc.dg/lto/20090213 c_lto_20090213_0.o-c_lto_20090213_1.o execute -O2 -flto -flto-partition=1to1
FAIL: gcc.dg/lto/20100227-1 c_lto_20100227-1_0.o-c_lto_20100227-1_1.o link, -O0 -flto -flto-partition=none
UNRESOLVED: gcc.dg/lto/20100227-1 c_lto_20100227-1_0.o-c_lto_20100227-1_1.o execute -O0 -flto -flto-partition=none
FAIL: gcc.dg/lto/20100227-1 c_lto_20100227-1_0.o-c_lto_20100227-1_1.o link, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.dg/lto/20100227-1 c_lto_20100227-1_0.o-c_lto_20100227-1_1.o execute -O2 -flto -flto-partition=none
FAIL: gcc.dg/lto/20100227-1 c_lto_20100227-1_0.o-c_lto_20100227-1_1.o link, -O0 -flto -flto-partition=1to1
UNRESOLVED: gcc.dg/lto/20100227-1 c_lto_20100227-1_0.o-c_lto_20100227-1_1.o execute -O0 -flto -flto-partition=1to1
FAIL: gcc.dg/lto/20100227-1 c_lto_20100227-1_0.o-c_lto_20100227-1_1.o link, -O2 -flto -flto-partition=1to1
UNRESOLVED: gcc.dg/lto/20100227-1 c_lto_20100227-1_0.o-c_lto_20100227-1_1.o execute -O2 -flto -flto-partition=1to1
FAIL: gcc.dg/lto/pr46940 c_lto_pr46940_0.o-c_lto_pr46940_1.o link, -O0 -flto -flto-partition=none
UNRESOLVED: gcc.dg/lto/pr46940 c_lto_pr46940_0.o-c_lto_pr46940_1.o execute -O0 -flto -flto-partition=none
FAIL: gcc.dg/lto/pr46940 c_lto_pr46940_0.o-c_lto_pr46940_1.o link, -O2 -flto -flto-partition=none
UNRESOLVED: gcc.dg/lto/pr46940 c_lto_pr46940_0.o-c_lto_pr46940_1.o execute -O2 -flto -flto-partition=none
FAIL: gcc.dg/lto/pr46940 c_lto_pr46940_0.o-c_lto_pr46940_1.o link, -O0 -flto -flto-partition=1to1
UNRESOLVED: gcc.dg/lto/pr46940 c_lto_pr46940_0.o-c_lto_pr46940_1.o execute -O0 -flto -flto-partition=1to1
FAIL: gcc.dg/lto/pr46940 c_lto_pr46940_0.o-c_lto_pr46940_1.o link, -O2 -flto -flto-partition=1to1
UNRESOLVED: gcc.dg/lto/pr46940 c_lto_pr46940_0.o-c_lto_pr46940_1.o execute -O2 -flto -flto-partition=1to1
FAIL: gcc.dg/special/gcsec-1.c execution test
FAIL: gcc.dg/torture/builtin-math-7.c -O0 execution test
FAIL: gcc.dg/torture/builtin-math-7.c -O1 execution test
FAIL: gcc.dg/torture/builtin-math-7.c -O2 execution test
FAIL: gcc.dg/torture/builtin-math-7.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/builtin-math-7.c -O3 -fomit-frame-pointer -funroll-loops execution test
FAIL: gcc.dg/torture/builtin-math-7.c -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions execution test
FAIL: gcc.dg/torture/builtin-math-7.c -O3 -g execution test
FAIL: gcc.dg/torture/builtin-math-7.c -Os execution test
FAIL: gcc.dg/torture/builtin-math-7.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/builtin-math-7.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/setjmp-1.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/setjmp-1.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/setjmp-1.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/setjmp-1.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/setjmp-1.c -O3 -fomit-frame-pointer -funroll-loops execution test
FAIL: gcc.dg/torture/stackalign/setjmp-1.c -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions execution test
FAIL: gcc.dg/torture/stackalign/setjmp-1.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/setjmp-1.c -Os execution test
FAIL: gcc.dg/torture/stackalign/setjmp-1.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/setjmp-1.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/alloca-1.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/alloca-1.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/builtin-apply-4.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/builtin-return-1.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/builtin-return-1.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/builtin-return-1.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/builtin-return-1.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/builtin-return-1.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/builtin-return-1.c -Os execution test
FAIL: gcc.dg/torture/stackalign/builtin-return-1.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/builtin-return-1.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/comp-goto-1.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/comp-goto-1.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/comp-goto-1.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/comp-goto-1.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/comp-goto-1.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/comp-goto-1.c -Os execution test
FAIL: gcc.dg/torture/stackalign/comp-goto-1.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/comp-goto-1.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/inline-2.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/inline-2.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/nested-3.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/nested-3.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/nested-5.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/nested-5.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/nested-5.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/nested-5.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/nested-5.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/nested-5.c -Os execution test
FAIL: gcc.dg/torture/stackalign/nested-5.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/nested-5.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/nested-6.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/nested-6.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/nested-6.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/nested-6.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/nested-6.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/nested-6.c -Os execution test
FAIL: gcc.dg/torture/stackalign/nested-6.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/nested-6.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-1.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-1.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-1.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-1.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-1.c -O3 -fomit-frame-pointer -funroll-loops execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-1.c -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-1.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-1.c -Os execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-1.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-1.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-2.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-2.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-2.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-2.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-2.c -O3 -fomit-frame-pointer -funroll-loops execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-2.c -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-2.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-2.c -Os execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-2.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-2.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-3.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-3.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-3.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-3.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-3.c -O3 -fomit-frame-pointer -funroll-loops execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-3.c -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-3.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-3.c -Os execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-3.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-3.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-4.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-4.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-4.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-4.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-4.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-4.c -Os execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-4.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-4.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-5.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-5.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-5.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-5.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-5.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-5.c -Os execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-5.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/non-local-goto-5.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/ret-struct-1.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/ret-struct-1.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/ret-struct-1.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/ret-struct-1.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/ret-struct-1.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/ret-struct-1.c -Os execution test
FAIL: gcc.dg/torture/stackalign/ret-struct-1.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/ret-struct-1.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/setjmp-3.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/setjmp-3.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/setjmp-3.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/setjmp-3.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/setjmp-3.c -O3 -fomit-frame-pointer -funroll-loops execution test
FAIL: gcc.dg/torture/stackalign/setjmp-3.c -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions execution test
FAIL: gcc.dg/torture/stackalign/setjmp-3.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/setjmp-3.c -Os execution test
FAIL: gcc.dg/torture/stackalign/setjmp-3.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/setjmp-3.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/setjmp-4.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/setjmp-4.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/setjmp-4.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/setjmp-4.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/setjmp-4.c -O3 -fomit-frame-pointer -funroll-loops execution test
FAIL: gcc.dg/torture/stackalign/setjmp-4.c -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions execution test
FAIL: gcc.dg/torture/stackalign/setjmp-4.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/setjmp-4.c -Os execution test
FAIL: gcc.dg/torture/stackalign/setjmp-4.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/setjmp-4.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/sibcall-1.c -O0 execution test
FAIL: gcc.dg/torture/stackalign/sibcall-1.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/sibcall-1.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/sibcall-1.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/sibcall-1.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/sibcall-1.c -Os execution test
FAIL: gcc.dg/torture/stackalign/sibcall-1.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/sibcall-1.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/vararg-1.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/vararg-1.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/vararg-1.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/vararg-1.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/vararg-1.c -Os execution test
FAIL: gcc.dg/torture/stackalign/vararg-1.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/vararg-1.c -O2 -flto execution test
FAIL: gcc.dg/torture/stackalign/vararg-2.c -O1 execution test
FAIL: gcc.dg/torture/stackalign/vararg-2.c -O2 execution test
FAIL: gcc.dg/torture/stackalign/vararg-2.c -O3 -fomit-frame-pointer execution test
FAIL: gcc.dg/torture/stackalign/vararg-2.c -O3 -g execution test
FAIL: gcc.dg/torture/stackalign/vararg-2.c -Os execution test
FAIL: gcc.dg/torture/stackalign/vararg-2.c -O2 -flto -flto-partition=none execution test
FAIL: gcc.dg/torture/stackalign/vararg-2.c -O2 -flto execution test
FAIL: gcc.dg/vect/pr18400.c execution test
FAIL: gcc.dg/vect/pr18536.c execution test
FAIL: gcc.dg/vect/pr20122.c execution test
FAIL: gcc.dg/vect/pr30784.c execution test
FAIL: gcc.dg/vect/pr36493.c execution test
FAIL: gcc.dg/vect/pr37539.c execution test
FAIL: gcc.dg/vect/pr40074.c execution test
FAIL: gcc.dg/vect/pr40254.c execution test
FAIL: gcc.dg/vect/pr43430-1.c execution test
FAIL: gcc.dg/vect/pr44507.c execution test
FAIL: gcc.dg/vect/pr45752.c execution test
FAIL: gcc.dg/vect/pr45902.c execution test
FAIL: gcc.dg/vect/pr46009.c execution test
FAIL: gcc.dg/vect/vect-100.c execution test
FAIL: gcc.dg/vect/vect-103.c execution test
FAIL: gcc.dg/vect/vect-104.c execution test
FAIL: gcc.dg/vect/vect-105.c execution test
FAIL: gcc.dg/vect/vect-106.c execution test
FAIL: gcc.dg/vect/vect-109.c execution test
FAIL: gcc.dg/vect/vect-112.c execution test
FAIL: gcc.dg/vect/vect-115.c execution test
FAIL: gcc.dg/vect/vect-116.c execution test
FAIL: gcc.dg/vect/vect-117.c execution test
FAIL: gcc.dg/vect/vect-12.c execution test
FAIL: gcc.dg/vect/vect-13.c execution test
FAIL: gcc.dg/vect/vect-14.c execution test
FAIL: gcc.dg/vect/vect-15.c execution test
FAIL: gcc.dg/vect/vect-17.c execution test
FAIL: gcc.dg/vect/vect-18.c execution test
FAIL: gcc.dg/vect/vect-19.c execution test
FAIL: gcc.dg/vect/vect-2.c execution test
FAIL: gcc.dg/vect/vect-20.c execution test
FAIL: gcc.dg/vect/vect-21.c execution test
FAIL: gcc.dg/vect/vect-23.c execution test
FAIL: gcc.dg/vect/vect-24.c execution test
FAIL: gcc.dg/vect/vect-25.c execution test
FAIL: gcc.dg/vect/vect-26.c execution test
FAIL: gcc.dg/vect/vect-27.c execution test
FAIL: gcc.dg/vect/vect-28.c execution test
FAIL: gcc.dg/vect/vect-29.c execution test
FAIL: gcc.dg/vect/vect-31.c execution test
FAIL: gcc.dg/vect/vect-32.c execution test
FAIL: gcc.dg/vect/vect-34.c execution test
FAIL: gcc.dg/vect/vect-35.c execution test
FAIL: gcc.dg/vect/vect-36.c execution test
FAIL: gcc.dg/vect/vect-62.c execution test
FAIL: gcc.dg/vect/vect-63.c execution test
FAIL: gcc.dg/vect/vect-64.c execution test
FAIL: gcc.dg/vect/vect-65.c execution test
FAIL: gcc.dg/vect/vect-66.c execution test
FAIL: gcc.dg/vect/vect-67.c execution test
FAIL: gcc.dg/vect/vect-68.c execution test
FAIL: gcc.dg/vect/vect-7.c execution test
FAIL: gcc.dg/vect/vect-70.c execution test
FAIL: gcc.dg/vect/vect-71.c execution test
FAIL: gcc.dg/vect/vect-72.c execution test
FAIL: gcc.dg/vect/vect-73.c execution test
FAIL: gcc.dg/vect/vect-75.c execution test
FAIL: gcc.dg/vect/vect-76.c execution test
FAIL: gcc.dg/vect/vect-77-alignchecks.c execution test
FAIL: gcc.dg/vect/vect-77-global.c execution test
FAIL: gcc.dg/vect/vect-77.c execution test
FAIL: gcc.dg/vect/vect-78-alignchecks.c execution test
FAIL: gcc.dg/vect/vect-78-global.c execution test
FAIL: gcc.dg/vect/vect-78.c execution test
FAIL: gcc.dg/vect/vect-85.c execution test
FAIL: gcc.dg/vect/vect-86.c execution test
FAIL: gcc.dg/vect/vect-87.c execution test
FAIL: gcc.dg/vect/vect-88.c execution test
FAIL: gcc.dg/vect/vect-89.c execution test
FAIL: gcc.dg/vect/vect-9.c execution test
FAIL: gcc.dg/vect/vect-96.c execution test
FAIL: gcc.dg/vect/vect-97.c execution test
FAIL: gcc.dg/vect/vect-98.c execution test
FAIL: gcc.dg/vect/vect-99.c execution test
FAIL: gcc.dg/vect/vect-align-1.c execution test
FAIL: gcc.dg/vect/vect-align-2.c execution test
FAIL: gcc.dg/vect/vect-complex-4.c execution test
FAIL: gcc.dg/vect/vect-complex-5.c execution test
FAIL: gcc.dg/vect/vect-double-reduc-3.c execution test
FAIL: gcc.dg/vect/vect-double-reduc-7.c execution test
FAIL: gcc.dg/vect/vect-iv-1.c execution test
FAIL: gcc.dg/vect/vect-iv-10.c execution test
FAIL: gcc.dg/vect/vect-iv-11.c execution test
FAIL: gcc.dg/vect/vect-iv-2.c execution test
FAIL: gcc.dg/vect/vect-iv-3.c execution test
FAIL: gcc.dg/vect/vect-iv-4.c execution test
FAIL: gcc.dg/vect/vect-iv-5.c execution test
FAIL: gcc.dg/vect/vect-iv-7.c execution test
FAIL: gcc.dg/vect/vect-iv-8.c execution test
FAIL: gcc.dg/vect/vect-iv-8a.c execution test
FAIL: gcc.dg/vect/vect-iv-9.c execution test
FAIL: gcc.dg/vect/vect-multitypes-1.c execution test
FAIL: gcc.dg/vect/vect-multitypes-10.c execution test
FAIL: gcc.dg/vect/vect-multitypes-11.c execution test
FAIL: gcc.dg/vect/vect-multitypes-12.c execution test
FAIL: gcc.dg/vect/vect-multitypes-13.c execution test
FAIL: gcc.dg/vect/vect-multitypes-14.c execution test
FAIL: gcc.dg/vect/vect-multitypes-15.c execution test
FAIL: gcc.dg/vect/vect-multitypes-2.c execution test
FAIL: gcc.dg/vect/vect-multitypes-3.c execution test
FAIL: gcc.dg/vect/vect-multitypes-4.c execution test
FAIL: gcc.dg/vect/vect-multitypes-5.c execution test
FAIL: gcc.dg/vect/vect-multitypes-6.c execution test
FAIL: gcc.dg/vect/vect-multitypes-7.c execution test
FAIL: gcc.dg/vect/vect-multitypes-8.c execution test
FAIL: gcc.dg/vect/vect-multitypes-9.c execution test
FAIL: gcc.dg/vect/vect-outer-4f.c execution test
FAIL: gcc.dg/vect/vect-outer-4g.c execution test
FAIL: gcc.dg/vect/vect-outer-4i.c execution test
FAIL: gcc.dg/vect/vect-outer-4k.c execution test
FAIL: gcc.dg/vect/vect-outer-4l.c execution test
FAIL: gcc.dg/vect/vect-outer-4m.c execution test
FAIL: gcc.dg/vect/vect-peel-1.c execution test
FAIL: gcc.dg/vect/vect-peel-2.c execution test
FAIL: gcc.dg/vect/vect-peel-3.c execution test
FAIL: gcc.dg/vect/vect-peel-4.c execution test
FAIL: gcc.dg/vect/vect-reduc-1.c execution test
FAIL: gcc.dg/vect/vect-reduc-1char.c execution test
FAIL: gcc.dg/vect/vect-reduc-1short.c execution test
FAIL: gcc.dg/vect/vect-reduc-2.c execution test
FAIL: gcc.dg/vect/vect-reduc-2char.c execution test
FAIL: gcc.dg/vect/vect-reduc-2short.c execution test
FAIL: gcc.dg/vect/vect-reduc-3.c execution test
FAIL: gcc.dg/vect/vect-reduc-7.c execution test
FAIL: gcc.dg/vect/vect-reduc-8.c execution test
FAIL: gcc.dg/vect/vect-reduc-9.c execution test
FAIL: gcc.dg/vect/vect-reduc-dot-s16a.c execution test
FAIL: gcc.dg/vect/vect-reduc-dot-s16b.c execution test
FAIL: gcc.dg/vect/vect-reduc-dot-s8a.c execution test
FAIL: gcc.dg/vect/vect-reduc-dot-s8b.c execution test
FAIL: gcc.dg/vect/vect-reduc-dot-s8c.c execution test
FAIL: gcc.dg/vect/vect-reduc-dot-u16a.c execution test
FAIL: gcc.dg/vect/vect-reduc-dot-u16b.c execution test
FAIL: gcc.dg/vect/vect-reduc-dot-u8a.c execution test
FAIL: gcc.dg/vect/vect-reduc-dot-u8b.c execution test
FAIL: gcc.dg/vect/vect-reduc-pattern-1a.c execution test
FAIL: gcc.dg/vect/vect-reduc-pattern-1b.c execution test
FAIL: gcc.dg/vect/vect-reduc-pattern-1c.c execution test
FAIL: gcc.dg/vect/vect-reduc-pattern-2a.c execution test
FAIL: gcc.dg/vect/vect-reduc-pattern-2b.c execution test
FAIL: gcc.dg/vect/vect-reduc-pattern-2c.c execution test
FAIL: gcc.dg/vect/vect-strided-a-mult.c execution test
FAIL: gcc.dg/vect/vect-strided-a-u16-i2.c execution test
FAIL: gcc.dg/vect/vect-strided-a-u16-i4.c execution test
FAIL: gcc.dg/vect/vect-strided-a-u16-mult.c execution test
FAIL: gcc.dg/vect/vect-strided-a-u32-mult.c execution test
FAIL: gcc.dg/vect/vect-strided-a-u8-i2-gap.c execution test
FAIL: gcc.dg/vect/vect-strided-a-u8-i8-gap2.c execution test
FAIL: gcc.dg/vect/vect-strided-a-u8-i8-gap7.c execution test
FAIL: gcc.dg/vect/vect-strided-mult-char-ls.c execution test
FAIL: gcc.dg/vect/vect-strided-mult.c execution test
FAIL: gcc.dg/vect/vect-strided-same-dr.c execution test
FAIL: gcc.dg/vect/vect-strided-store-a-u8-i2.c execution test
FAIL: gcc.dg/vect/vect-strided-store-u16-i4.c execution test
FAIL: gcc.dg/vect/vect-strided-store-u32-i2.c execution test
FAIL: gcc.dg/vect/vect-strided-u16-i2.c execution test
FAIL: gcc.dg/vect/vect-strided-u16-i4.c execution test
FAIL: gcc.dg/vect/vect-strided-u32-i4.c execution test
FAIL: gcc.dg/vect/vect-strided-u32-i8.c execution test
FAIL: gcc.dg/vect/vect-strided-u32-mult.c execution test
FAIL: gcc.dg/vect/vect-strided-u8-i2-gap.c execution test
FAIL: gcc.dg/vect/vect-strided-u8-i2.c execution test
FAIL: gcc.dg/vect/vect-strided-u8-i8-gap2.c execution test
FAIL: gcc.dg/vect/vect-strided-u8-i8-gap4.c execution test
FAIL: gcc.dg/vect/vect-strided-u8-i8-gap7.c execution test
FAIL: gcc.dg/vect/vect-strided-u8-i8.c execution test
FAIL: gcc.dg/vect/vect-vfa-01.c execution test
FAIL: gcc.dg/vect/vect-vfa-02.c execution test
FAIL: gcc.dg/vect/vect-vfa-03.c execution test
FAIL: gcc.dg/vect/vect-vfa-04.c execution test
FAIL: gcc.dg/vect/vect-vfa-slp.c execution test
FAIL: gcc.dg/vect/vect-widen-mult-s16.c execution test
FAIL: gcc.dg/vect/vect-widen-mult-s8.c execution test
FAIL: gcc.dg/vect/vect-widen-mult-sum.c execution test
FAIL: gcc.dg/vect/vect-widen-mult-u16.c execution test
FAIL: gcc.dg/vect/vect-widen-mult-u8.c execution test
FAIL: gcc.dg/vect/slp-1.c execution test
FAIL: gcc.dg/vect/slp-10.c execution test
FAIL: gcc.dg/vect/slp-11.c execution test
FAIL: gcc.dg/vect/slp-12a.c execution test
FAIL: gcc.dg/vect/slp-13.c execution test
FAIL: gcc.dg/vect/slp-14.c execution test
FAIL: gcc.dg/vect/slp-15.c execution test
FAIL: gcc.dg/vect/slp-16.c execution test
FAIL: gcc.dg/vect/slp-17.c execution test
FAIL: gcc.dg/vect/slp-19.c execution test
FAIL: gcc.dg/vect/slp-2.c execution test
FAIL: gcc.dg/vect/slp-20.c execution test
FAIL: gcc.dg/vect/slp-21.c execution test
FAIL: gcc.dg/vect/slp-22.c execution test
FAIL: gcc.dg/vect/slp-23.c execution test
FAIL: gcc.dg/vect/slp-24.c execution test
FAIL: gcc.dg/vect/slp-25.c execution test
FAIL: gcc.dg/vect/slp-26.c execution test
FAIL: gcc.dg/vect/slp-28.c execution test
FAIL: gcc.dg/vect/slp-3.c execution test
FAIL: gcc.dg/vect/slp-33.c execution test
FAIL: gcc.dg/vect/slp-34.c execution test
FAIL: gcc.dg/vect/slp-35.c execution test
FAIL: gcc.dg/vect/slp-37.c execution test
FAIL: gcc.dg/vect/slp-4.c execution test
FAIL: gcc.dg/vect/slp-5.c execution test
FAIL: gcc.dg/vect/slp-6.c execution test
FAIL: gcc.dg/vect/slp-7.c execution test
FAIL: gcc.dg/vect/slp-8.c execution test
FAIL: gcc.dg/vect/slp-9.c execution test
FAIL: gcc.dg/vect/slp-multitypes-1.c execution test
FAIL: gcc.dg/vect/slp-multitypes-10.c execution test
FAIL: gcc.dg/vect/slp-multitypes-11.c execution test
FAIL: gcc.dg/vect/slp-multitypes-12.c execution test
FAIL: gcc.dg/vect/slp-multitypes-3.c execution test
FAIL: gcc.dg/vect/slp-multitypes-4.c execution test
FAIL: gcc.dg/vect/slp-multitypes-5.c execution test
FAIL: gcc.dg/vect/slp-multitypes-6.c execution test
FAIL: gcc.dg/vect/slp-multitypes-7.c execution test
FAIL: gcc.dg/vect/slp-multitypes-8.c execution test
FAIL: gcc.dg/vect/slp-multitypes-9.c execution test
FAIL: gcc.dg/vect/slp-perm-1.c execution test
FAIL: gcc.dg/vect/slp-perm-2.c execution test
FAIL: gcc.dg/vect/slp-perm-3.c execution test
FAIL: gcc.dg/vect/slp-perm-4.c execution test
FAIL: gcc.dg/vect/slp-perm-5.c execution test
FAIL: gcc.dg/vect/slp-perm-6.c execution test
FAIL: gcc.dg/vect/slp-perm-7.c execution test
FAIL: gcc.dg/vect/slp-perm-8.c execution test
FAIL: gcc.dg/vect/slp-perm-9.c execution test
FAIL: gcc.dg/vect/slp-reduc-1.c execution test
FAIL: gcc.dg/vect/slp-reduc-2.c execution test
FAIL: gcc.dg/vect/slp-reduc-3.c execution test
FAIL: gcc.dg/vect/slp-reduc-4.c execution test
FAIL: gcc.dg/vect/slp-reduc-5.c execution test
FAIL: gcc.dg/vect/slp-reduc-6.c execution test
FAIL: gcc.dg/vect/slp-widen-mult-s16.c execution test
FAIL: gcc.dg/vect/slp-widen-mult-u8.c execution test
FAIL: gcc.dg/vect/bb-slp-1.c execution test
FAIL: gcc.dg/vect/bb-slp-10.c execution test
FAIL: gcc.dg/vect/bb-slp-11.c execution test
FAIL: gcc.dg/vect/bb-slp-13.c execution test
FAIL: gcc.dg/vect/bb-slp-14.c execution test
FAIL: gcc.dg/vect/bb-slp-15.c execution test
FAIL: gcc.dg/vect/bb-slp-16.c execution test
FAIL: gcc.dg/vect/bb-slp-17.c execution test
FAIL: gcc.dg/vect/bb-slp-18.c execution test
FAIL: gcc.dg/vect/bb-slp-19.c execution test
FAIL: gcc.dg/vect/bb-slp-2.c execution test
FAIL: gcc.dg/vect/bb-slp-20.c execution test
FAIL: gcc.dg/vect/bb-slp-21.c execution test
FAIL: gcc.dg/vect/bb-slp-22.c execution test
FAIL: gcc.dg/vect/bb-slp-23.c execution test
FAIL: gcc.dg/vect/bb-slp-3.c execution test
FAIL: gcc.dg/vect/bb-slp-4.c execution test
FAIL: gcc.dg/vect/bb-slp-5.c execution test
FAIL: gcc.dg/vect/bb-slp-6.c execution test
FAIL: gcc.dg/vect/bb-slp-7.c execution test
FAIL: gcc.dg/vect/bb-slp-8.c execution test
FAIL: gcc.dg/vect/bb-slp-8a.c execution test
FAIL: gcc.dg/vect/bb-slp-8b.c execution test
FAIL: gcc.dg/vect/bb-slp-9.c execution test
FAIL: gcc.dg/vect/no-vfa-pr29145.c execution test
FAIL: gcc.dg/vect/no-vfa-vect-101.c execution test
FAIL: gcc.dg/vect/no-vfa-vect-102.c execution test
FAIL: gcc.dg/vect/no-vfa-vect-102a.c execution test
FAIL: gcc.dg/vect/no-vfa-vect-37.c execution test
FAIL: gcc.dg/vect/no-vfa-vect-depend-1.c execution test
FAIL: gcc.dg/vect/no-vfa-vect-dv-2.c execution test
FAIL: gcc.dg/vect/wrapv-vect-7.c execution test
FAIL: gcc.dg/vect/wrapv-vect-reduc-2char.c execution test
FAIL: gcc.dg/vect/wrapv-vect-reduc-2short.c execution test
FAIL: gcc.dg/vect/wrapv-vect-reduc-dot-s8b.c execution test
FAIL: gcc.dg/vect/wrapv-vect-reduc-pattern-2c.c execution test
FAIL: gcc.dg/vect/no-section-anchors-vect-31.c execution test
FAIL: gcc.dg/vect/no-section-anchors-vect-34.c execution test
FAIL: gcc.dg/vect/no-section-anchors-vect-36.c execution test
FAIL: gcc.dg/vect/no-section-anchors-vect-64.c execution test
FAIL: gcc.dg/vect/no-section-anchors-vect-65.c execution test
FAIL: gcc.dg/vect/no-section-anchors-vect-66.c execution test
FAIL: gcc.dg/vect/no-section-anchors-vect-68.c execution test
FAIL: gcc.dg/vect/no-section-anchors-vect-69.c execution test
FAIL: gcc.dg/vect/no-section-anchors-vect-outer-4h.c execution test
FAIL: gcc.dg/vect/no-scevccp-vect-iv-1.c execution test
FAIL: gcc.dg/vect/no-scevccp-vect-iv-2.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-10.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-10a.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-10b.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-11.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-12.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-13.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-14.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-15.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-16.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-17.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-18.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-19.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-20.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-21.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-22.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-3.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-4.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-5.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-6-global.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-6.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-7.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-8.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-9.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-9a.c execution test
FAIL: gcc.dg/vect/no-scevccp-outer-9b.c execution test
FAIL: gcc.dg/vect/no-scevccp-noreassoc-outer-1.c execution test
FAIL: gcc.dg/vect/no-scevccp-noreassoc-outer-2.c execution test
FAIL: gcc.dg/vect/no-scevccp-noreassoc-outer-3.c execution test
FAIL: gcc.dg/vect/no-scevccp-noreassoc-outer-4.c execution test
FAIL: gcc.dg/vect/no-scevccp-noreassoc-outer-5.c execution test
FAIL: gcc.dg/vect/no-scevccp-slp-30.c execution test
FAIL: gcc.dg/vect/no-scevccp-slp-31.c execution test
FAIL: gcc.dg/vect/no-tree-dom-vect-bug.c execution test
FAIL: gcc.dg/vect/no-tree-pre-slp-29.c execution test
FAIL: gcc.dg/vect/O3-vect-pr34223.c execution test
FAIL: gcc.dg/vect/no-tree-reassoc-bb-slp-12.c execution test
FAIL: gcc.target/sparc/20001013-1.c execution test
FAIL: gcc.target/sparc/20001101-1.c execution test
FAIL: gcc.target/sparc/pdist-3.c execution test
FAIL: gcc.target/sparc/sparc-ret.c scan-assembler return[ \\t]*%i7\\\\+8\\n[^\\n]*ld[ \\t]*\\\\[%sp\\\\+96\\\\]
FAIL: gcc.target/sparc/sparc-ret.c scan-assembler return[ \\t]*%i7\\\\+8\\n[^\\n]*nop
=== gcc Summary ===
# of expected passes 68033
# of unexpected failures 714
# of expected failures 227
# of unresolved testcases 128
# of unsupported tests 1237
/home2/joel/build/b-sparc-gcc/gcc/xgcc version 4.6.1 20110329 (prerelease) (GCC)
=== g++ tests ===
FAIL: g++.dg/eh/gcsec1.C execution test
FAIL: g++.dg/eh/simd-2.C (test for excess errors)
WARNING: g++.dg/eh/simd-2.C compilation failed to produce executable
FAIL: g++.dg/init/array15.C execution test
FAIL: g++.dg/init/array16.C execution test
FAIL: g++.dg/special/conpr-2.C execution test
FAIL: g++.dg/special/conpr-4.C execution test
FAIL: g++.dg/special/initp1.C execution test
FAIL: g++.dg/special/initpri1.C execution test
FAIL: g++.dg/torture/pr37922.C -O0 (test for excess errors)
WARNING: g++.dg/torture/pr37922.C -O0 compilation failed to produce executable
FAIL: g++.dg/torture/pr37922.C -O1 (test for excess errors)
WARNING: g++.dg/torture/pr37922.C -O1 compilation failed to produce executable
FAIL: g++.dg/torture/pr37922.C -O2 (test for excess errors)
WARNING: g++.dg/torture/pr37922.C -O2 compilation failed to produce executable
FAIL: g++.dg/torture/pr37922.C -O3 -fomit-frame-pointer (test for excess errors)
WARNING: g++.dg/torture/pr37922.C -O3 -fomit-frame-pointer compilation failed to produce executable
FAIL: g++.dg/torture/pr37922.C -O3 -fomit-frame-pointer -funroll-loops (test for excess errors)
WARNING: g++.dg/torture/pr37922.C -O3 -fomit-frame-pointer -funroll-loops compilation failed to produce executable
FAIL: g++.dg/torture/pr37922.C -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions (test for excess errors)
WARNING: g++.dg/torture/pr37922.C -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions compilation failed to produce executable
FAIL: g++.dg/torture/pr37922.C -O3 -g (test for excess errors)
WARNING: g++.dg/torture/pr37922.C -O3 -g compilation failed to produce executable
FAIL: g++.dg/torture/pr37922.C -Os (test for excess errors)
WARNING: g++.dg/torture/pr37922.C -Os compilation failed to produce executable
FAIL: g++.dg/torture/pr37922.C -O2 -flto -flto-partition=none (test for excess errors)
WARNING: g++.dg/torture/pr37922.C -O2 -flto -flto-partition=none compilation failed to produce executable
FAIL: g++.dg/torture/pr37922.C -O2 -flto (test for excess errors)
WARNING: g++.dg/torture/pr37922.C -O2 -flto compilation failed to produce executable
FAIL: g++.dg/torture/pr39002.C -O2 -flto -flto-partition=none (test for excess errors)
WARNING: g++.dg/torture/pr39002.C -O2 -flto -flto-partition=none compilation failed to produce executable
FAIL: g++.dg/torture/pr39002.C -O2 -flto (test for excess errors)
WARNING: g++.dg/torture/pr39002.C -O2 -flto compilation failed to produce executable
FAIL: g++.dg/torture/stackalign/eh-alloca-1.C -O0 execution test
FAIL: g++.dg/torture/stackalign/eh-alloca-1.C -O1 execution test
FAIL: g++.dg/torture/stackalign/eh-alloca-1.C -O2 execution test
FAIL: g++.dg/torture/stackalign/eh-alloca-1.C -O3 -fomit-frame-pointer execution test
FAIL: g++.dg/torture/stackalign/eh-alloca-1.C -O3 -g execution test
FAIL: g++.dg/torture/stackalign/eh-alloca-1.C -Os execution test
FAIL: g++.dg/torture/stackalign/eh-alloca-1.C -O2 -flto -flto-partition=none execution test
FAIL: g++.dg/torture/stackalign/eh-alloca-1.C -O2 -flto execution test
FAIL: g++.dg/torture/stackalign/eh-global-1.C -O0 execution test
FAIL: g++.dg/torture/stackalign/eh-global-1.C -O1 execution test
FAIL: g++.dg/torture/stackalign/eh-global-1.C -O2 execution test
FAIL: g++.dg/torture/stackalign/eh-global-1.C -O3 -fomit-frame-pointer execution test
FAIL: g++.dg/torture/stackalign/eh-global-1.C -O3 -g execution test
FAIL: g++.dg/torture/stackalign/eh-global-1.C -Os execution test
FAIL: g++.dg/torture/stackalign/eh-global-1.C -O2 -flto -flto-partition=none execution test
FAIL: g++.dg/torture/stackalign/eh-global-1.C -O2 -flto execution test
FAIL: g++.dg/torture/stackalign/eh-inline-1.C -O0 execution test
FAIL: g++.dg/torture/stackalign/eh-inline-1.C -O1 execution test
FAIL: g++.dg/torture/stackalign/eh-inline-1.C -O2 execution test
FAIL: g++.dg/torture/stackalign/eh-inline-1.C -O3 -fomit-frame-pointer execution test
FAIL: g++.dg/torture/stackalign/eh-inline-1.C -O3 -g execution test
FAIL: g++.dg/torture/stackalign/eh-inline-1.C -Os execution test
FAIL: g++.dg/torture/stackalign/eh-inline-1.C -O2 -flto -flto-partition=none execution test
FAIL: g++.dg/torture/stackalign/eh-inline-1.C -O2 -flto execution test
FAIL: g++.dg/torture/stackalign/eh-inline-2.C -O0 execution test
FAIL: g++.dg/torture/stackalign/eh-inline-2.C -O1 execution test
FAIL: g++.dg/torture/stackalign/eh-inline-2.C -O2 execution test
FAIL: g++.dg/torture/stackalign/eh-inline-2.C -O3 -fomit-frame-pointer execution test
FAIL: g++.dg/torture/stackalign/eh-inline-2.C -O3 -g execution test
FAIL: g++.dg/torture/stackalign/eh-inline-2.C -Os execution test
FAIL: g++.dg/torture/stackalign/eh-inline-2.C -O2 -flto -flto-partition=none execution test
FAIL: g++.dg/torture/stackalign/eh-inline-2.C -O2 -flto execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-1.C -O0 execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-1.C -O1 execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-1.C -O2 execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-1.C -O3 -fomit-frame-pointer execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-1.C -O3 -g execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-1.C -Os execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-1.C -O2 -flto -flto-partition=none execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-1.C -O2 -flto execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-2.C -O0 execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-2.C -O1 execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-2.C -O2 execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-2.C -O3 -fomit-frame-pointer execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-2.C -O3 -g execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-2.C -Os execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-2.C -O2 -flto -flto-partition=none execution test
FAIL: g++.dg/torture/stackalign/eh-vararg-2.C -O2 -flto execution test
FAIL: g++.dg/torture/stackalign/throw-1.C -O1 execution test
FAIL: g++.dg/torture/stackalign/throw-1.C -O2 execution test
FAIL: g++.dg/torture/stackalign/throw-1.C -O3 -fomit-frame-pointer execution test
FAIL: g++.dg/torture/stackalign/throw-1.C -O3 -fomit-frame-pointer -funroll-loops execution test
FAIL: g++.dg/torture/stackalign/throw-1.C -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions execution test
FAIL: g++.dg/torture/stackalign/throw-1.C -O3 -g execution test
FAIL: g++.dg/torture/stackalign/throw-1.C -Os execution test
FAIL: g++.dg/torture/stackalign/throw-2.C -O1 execution test
FAIL: g++.dg/torture/stackalign/throw-2.C -O2 execution test
FAIL: g++.dg/torture/stackalign/throw-2.C -O3 -fomit-frame-pointer execution test
FAIL: g++.dg/torture/stackalign/throw-2.C -O3 -fomit-frame-pointer -funroll-loops execution test
FAIL: g++.dg/torture/stackalign/throw-2.C -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions execution test
FAIL: g++.dg/torture/stackalign/throw-2.C -O3 -g execution test
FAIL: g++.dg/torture/stackalign/throw-2.C -Os execution test
FAIL: g++.dg/torture/stackalign/throw-3.C -O1 execution test
FAIL: g++.dg/torture/stackalign/throw-3.C -O2 execution test
FAIL: g++.dg/torture/stackalign/throw-3.C -O3 -fomit-frame-pointer execution test
FAIL: g++.dg/torture/stackalign/throw-3.C -O3 -fomit-frame-pointer -funroll-loops execution test
FAIL: g++.dg/torture/stackalign/throw-3.C -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions execution test
FAIL: g++.dg/torture/stackalign/throw-3.C -O3 -g execution test
FAIL: g++.dg/torture/stackalign/throw-3.C -Os execution test
FAIL: g++.dg/torture/stackalign/throw-4.C -O1 execution test
FAIL: g++.dg/torture/stackalign/throw-4.C -O2 execution test
FAIL: g++.dg/torture/stackalign/throw-4.C -O3 -fomit-frame-pointer execution test
FAIL: g++.dg/torture/stackalign/throw-4.C -O3 -fomit-frame-pointer -funroll-loops execution test
FAIL: g++.dg/torture/stackalign/throw-4.C -O3 -fomit-frame-pointer -funroll-all-loops -finline-functions execution test
FAIL: g++.dg/torture/stackalign/throw-4.C -O3 -g execution test
FAIL: g++.dg/torture/stackalign/throw-4.C -Os execution test
FAIL: g++.old-deja/g++.other/comdat5.C (test for excess errors)
XPASS: g++.old-deja/g++.other/init19.C execution test
=== g++ Summary ===
# of expected passes 25343
# of unexpected failures 97
# of unexpected successes 1
# of expected failures 161
# of unsupported tests 446
/home2/joel/build/b-sparc-gcc/gcc/testsuite/g++/../../g++ version 4.6.1 20110329 (prerelease) (GCC)
Compiler version: 4.6.1 20110329 (prerelease) (GCC)
Platform: sparc-unknown-rtems4.11
configure flags: --with-ppl=/users/joel/test-gcc/install-4.6-branch --disable-werror --enable-threads=rtems --with-gnu-as --enable-multilib --enable-newlib-mb --enable-newlib-iconv --with-gnu-ld --with-newlib --verbose --with-system-zlib --disable-nls --enable-version-specific-runtime-libs --enable-languages=c,c++ --target=sparc-rtems4.11 --prefix=/users/joel/test-gcc/install-4.6-branch
More information about the rtems-tooltestresults
