ACATS results for 20090122 (experimental) [trunk revision 143574] on mips-rtems4.10
Joel Sherrill <joel.sherrill@rtems.org>
joel at rtems.org
Fri Jan 23 11:21:44 CST 2009
HOST: i686-pc-linux-gnu
mips-rtems4.10-gcc (GCC) 4.4.0 20090122 (experimental) [trunk revision 143574]
=== acats Summary ===
# of expected passes 2309
# of unexpected failures 3
# of unsupported tests 3
ce2108f - simulator does not have persistent files
ce2108h - simulator does not have persistent files
ce3112d - simulator does not have persistent files
c380004 - read from bad address
cxf3a01 - read from bad address
cxf3a02 - read from bad address
======= Logs for failed tests ======
More information about the Rtems-tooltestresults
