[PATCH 15] shared-irq: add support for custom BSP vector verification
Gedare Bloom
gedare at rtems.org
Mon Feb 6 10:11:45 CST 2012
On Mon, Feb 6, 2012 at 9:15 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
> c/src/lib/libbsp/shared/include/irq-generic.h | 2 ++
> c/src/lib/libbsp/shared/include/irq.h | 8 ++++++++
> 2 files changed, 10 insertions(+), 0 deletions(-)
> diff --git a/c/src/lib/libbsp/shared/include/irq-generic.h b/c/src/lib/libbsp/shared/include/irq-generic.h
> index 5181952..3cbb7db 100644
> --- a/c/src/lib/libbsp/shared/include/irq-generic.h
> +++ b/c/src/lib/libbsp/shared/include/irq-generic.h
> @@ -134,6 +134,7 @@ static inline rtems_vector_number bsp_interrupt_handler_index(
> +#if !defined(BSP_INTERRUPT_CUSTOM_VALID_VECTOR)
> * @brief Returns true if the interrupt vector with number @a vector is valid.
> @@ -142,6 +143,7 @@ static inline bool bsp_interrupt_is_valid_vector(rtems_vector_number vector)
> return (rtems_vector_number) BSP_INTERRUPT_VECTOR_MIN <= vector
> && vector <= (rtems_vector_number) BSP_INTERRUPT_VECTOR_MAX;
> +#endif
> * @brief Default interrupt handler.
> diff --git a/c/src/lib/libbsp/shared/include/irq.h b/c/src/lib/libbsp/shared/include/irq.h
> index ae57bd1..19aed6f 100644
> --- a/c/src/lib/libbsp/shared/include/irq.h
> +++ b/c/src/lib/libbsp/shared/include/irq.h
> @@ -72,6 +72,14 @@
> typedef uint8_t bsp_interrupt_handler_index_type;
> #endif
> + * @brief Enable custom vector checking
> + * If defined the BSP must implement the custom bsp_interrupt_is_valid_vector()
> + * vector validator check routine.
> +#undef BSP_INTERRUPT_CUSTOM_VALID_VECTOR
> #endif /* LIBBSP_SHARED_IRQ_CONFIG_H */
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
I can see a possible reason for this patch could be when valid vectors
do not necessarily fall within a range [min,max] so this patch seems
reasonable.
More information about the rtems-devel
