[rtems-crossrpms commit] Add AM_MAINTAINER_MODE.
Chris Johns
chrisj at rtems.org
Sun Apr 29 21:31:48 CDT 2012
On 29/04/12 6:56 PM, Ralf Corsepius wrote:
> Module: rtems-crossrpms
> Branch: master
> Commit: f839675f62b514c156f86b2c055201f5bbc13dd7
> Changeset: http://git.rtems.org/rtems-crossrpms/commit/?id=f839675f62b514c156f86b2c055201f5bbc13dd7
> Author: Ralf Corsépius<ralf.corsepius at rtems.org>
> Date: Sun Apr 29 10:49:09 2012 +0200
> Remove TARGET_SUBDIRS.
Is this to fix the issue I posted in the other thread where the arm-eabi
spec file is not being created ?
> Makefile.am | 22 ++++++++++------------
> configure.ac | 13 +------------
> 2 files changed, 11 insertions(+), 24 deletions(-)
> diff --git a/Makefile.am b/Makefile.am
> index dd5b46b..3ec37f6 100644
> --- a/Makefile.am
> +++ b/Makefile.am
> @@ -4,19 +4,17 @@
> EXTRA_DIST =
> -SUBDIRS = @HOST_SUBDIRS@ @TARGET_SUBDIRS@
> +SUBDIRS = cygwin
> +SUBDIRS += freebsd6.4
> +SUBDIRS += freebsd7.3
> +SUBDIRS += freebsd8.2
> +SUBDIRS += freebsd9.0
> +SUBDIRS += mingw32
> +SUBDIRS += netbsd5.1
> +SUBDIRS += solaris2.7
> +SUBDIRS += rtems4.11
> -DIST_SUBDIRS = cygwin
> -DIST_SUBDIRS += freebsd6.4
> -DIST_SUBDIRS += freebsd7.3
> -DIST_SUBDIRS += freebsd8.2
> -DIST_SUBDIRS += freebsd9.0
> -DIST_SUBDIRS += mingw32
> -DIST_SUBDIRS += netbsd5.1
> -DIST_SUBDIRS += solaris2.7
> -DIST_SUBDIRS += rtems4.11
> -DIST_SUBDIRS += autotools
> +SUBDIRS += autotools
> EXTRA_DIST += specstrip
> EXTRA_DIST += $(srcdir)/patches/*.diff
> diff --git a/configure.ac b/configure.ac
> index dd46294..e874b8e 100644
> --- a/configure.ac
> +++ b/configure.ac
> @@ -12,6 +12,7 @@ AC_CANONICAL_HOST
> AC_PREFIX_DEFAULT([/opt/rtems-][RTEMS_API])
> AM_INIT_AUTOMAKE([1.11.1])
> +AM_MAINTAINER_MODE
> savdir=`pwd`
> cd $srcdir
> @@ -102,20 +103,8 @@ AC_ARG_ENABLE([infos],
> AC_SUBST(SPECSTRIP_OPTS)
> -for f in $targets; do
> -ac_cv_mytarget=`$SHELL "$ac_aux_dir/config.sub" $f` ||
> - AC_MSG_ERROR([$SHELL $ac_aux_dir/config.sub $f failed])
> - RTEMS_CANONICAL_SPLIT(mytarget)
> - AS_IF([test -d $srcdir/$mytarget_os/$mytarget_cpu],[
> - target_subdirs="$target_subdirs $mytarget_os/$mytarget_cpu"],[
> - AC_MSG_WARN([ignoring unsupported target $f])
> -done
> AM_CONDITIONAL([CUSTOM_RPMPREFIX],[test "$CUSTOM_RPMPREFIX" = "yes"])
> -AC_SUBST(TARGET_SUBDIRS,$target_subdirs)
> AC_SUBST(rtems_api,RTEMS_API)
> AC_CONFIG_FILES([Makefile])
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
More information about the rtems-devel
