[PATCH 34.5 v2 6/6] LEON3: added TX-wait-complete and CR on NL support for UART
Gedare Bloom
gedare at rtems.org
Thu Apr 19 11:23:36 CDT 2012
Are the new do_cr_on_newline and wait_sent boolean flags? can we use a
bool type? Maybe I'm being difficult but it just will be a little
easier to read the code I think. Otherwise I think this looks ok given
the rename patch coming up.
On Thu, Apr 19, 2012 at 9:21 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
> Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
> c/src/lib/libbsp/sparc/leon3/console/console.c | 11 +++++++----
> c/src/lib/libbsp/sparc/leon3/console/debugputs.c | 18 ++++++++++++++++--
> 2 files changed, 23 insertions(+), 6 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
> index aece47a..fc6d5b0 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/console.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
> @@ -50,8 +50,11 @@ int syscon_uart_index __attribute__((weak)) = 0;
> extern void apbuart_outbyte_polled(
> ambapp_apb_uart *regs,
> - char ch
> + unsigned char ch,
> + int do_cr_on_newline,
> + int wait_sent
> /* body is in debugputs.c */
> @@ -157,7 +160,7 @@ ssize_t console_write_polled(int minor, const char *buf, size_t len)
> port = minor - 1;
> while (nwrite < len) {
> - apbuart_outbyte_polled(apbuarts[port].regs, *buf++);
> + apbuart_outbyte_polled(apbuarts[port].regs, *buf++, 1, 0);
> nwrite++;
> return nwrite;
> @@ -324,7 +327,7 @@ rtems_device_driver console_initialize(
> * On a MP system one should not open UARTs that other OS instances use.
> if (syscon_uart_index < uarts) {
> - status = rtems_io_register_name( "/dev/console", major, 0 );
> + status = rtems_io_register_name("/dev/console", major, 0);
> if (status != RTEMS_SUCCESSFUL)
> rtems_fatal_error_occurred(status);
> diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> index 7058cf8..080d4fa 100644
> --- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> +++ b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
> @@ -89,9 +89,12 @@ int bsp_debug_uart_init(void)
> - unsigned char ch
> + unsigned char ch,
> + int wait_sent
> +send:
> while ( (regs->status & LEON_REG_UART_STATUS_THE) == 0 ) {
> /* Lower bus utilization while waiting for UART */
> asm volatile ("nop"::); asm volatile ("nop"::);
> @@ -100,6 +103,17 @@ void apbuart_outbyte_polled(
> regs->data = (unsigned int) ch;
> + if ((ch == '\n') && do_cr_on_newline) {
> + ch = '\r';
> + goto send;
> + /* Wait until the character has been sent? */
> + if (wait_sent) {
> + while ((regs->status & LEON_REG_UART_STATUS_THE) == 0)
> @@ -129,7 +143,7 @@ static void bsp_out_char(char c)
> return;
> - apbuart_outbyte_polled(dbg_uart, c);
> + apbuart_outbyte_polled(dbg_uart, c, 1, 1);
> 1.7.0.4
More information about the rtems-devel
