[PATCH] rbheap: API changes and documentation
sebastian.huber at embedded-brains.de sebastian.huber at embedded-brains.de
Mon Apr 16 03:39:41 CDT 2012
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
 cpukit/sapi/include/rtems/rbheap.h  |  129 ++++++++++++++++++++-----
 cpukit/sapi/src/rbheap.c            |  181 ++++++++++++++++++-----------------
 testsuites/libtests/rbheap01/init.c |   88 ++++++++++-------
 3 files changed, 247 insertions(+), 151 deletions(-)
diff --git a/cpukit/sapi/include/rtems/rbheap.h b/cpukit/sapi/include/rtems/rbheap.h
index be1eec6..47620d0 100644
--- a/cpukit/sapi/include/rtems/rbheap.h
+++ b/cpukit/sapi/include/rtems/rbheap.h
@@ -36,10 +36,14 @@ extern "C" {
  * @brief Red-Black Tree Heap API.
- * In the Red-Black Tree Heap the administration data structures are not
- * contained in the managed memory area.  This can be used for example in a
- * task stack allocator which protects the task stacks from access by other
- * tasks.
+ * The red-black tree heap provides a memory allocator suitable to implement
+ * the malloc() and free() interface.  In the red-black tree heap the
+ * administration data structures are not contained in the managed memory area.
+ * Thus writing beyond the boundaries of a chunk does not damage the data to
+ * maintain the heap.  This can be used for example in a task stack allocator
+ * which protects the task stacks from access by other tasks.  The allocated
+ * and free memory parts of the managed area are called chunks.  Each chunk
+ * needs a descriptor which is stored outside of the managed area.
@@ -49,47 +53,118 @@ typedef struct {
   rtems_rbtree_node tree_node;
   uintptr_t begin;
   uintptr_t size;
-} rtems_rbheap_page;
+} rtems_rbheap_chunk;
 typedef struct rtems_rbheap_control rtems_rbheap_control;
-typedef void (*rtems_rbheap_extend_page_pool)(rtems_rbheap_control *control);
+ * @brief Handler to extend the available chunk descriptors.
+ * This handler is called when no more chunk descriptors are available.  An
+ * example implementation is this:
+ * @code
+ * void extend_descriptors_with_malloc(rtems_rbheap_control *control)
+ *   rtems_rbheap_chunk *chunk = malloc(sizeof(*chunk));
+ *   if (chunk != NULL) {
+ *     rtems_rbheap_add_to_free_descriptor_chain(control, chunk);
+ * @endcode
+ * @see rtems_rbheap_extend_descriptors_never() and
+ * rtems_rbheap_extend_descriptors_with_malloc().
+typedef void (*rtems_rbheap_extend_descriptors)(rtems_rbheap_control *control);
 struct rtems_rbheap_control {
   rtems_chain_control free_chain;
-  rtems_chain_control pool_chain;
-  rtems_rbtree_control page_tree;
-  uintptr_t page_alignment;
-  rtems_rbheap_extend_page_pool extend_page_pool;
+  rtems_chain_control free_descriptor_chain;
+  rtems_rbtree_control chunk_tree;
+  uintptr_t alignment;
+  rtems_rbheap_extend_descriptors extend_descriptors;
   void *handler_arg;
+ * @brief Initializes the red-black tree heap @a control.
+ * @param[in, out] control The red-black tree heap.
+ * @param[in] area_begin The managed memory area begin.
+ * @param[in] area_size The managed memory area size.
+ * @param[in] alignment The minimum chunk alignment.
+ * @param[in] extend_descriptors The handler to extend the available chunk
+ * descriptors.
+ * @param[in] handler_arg The handler argument.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_NUMBER The alignment is not positive.
+ * @retval RTEMS_INVALID_ADDRESS The memory area is invalid.
+ * @retval RTEMS_NO_MEMORY Not enough chunk descriptors.
 rtems_status_code rtems_rbheap_initialize(
   rtems_rbheap_control *control,
   void *area_begin,
   uintptr_t area_size,
-  uintptr_t page_alignment,
-  rtems_rbheap_extend_page_pool extend_page_pool,
+  uintptr_t alignment,
+  rtems_rbheap_extend_descriptors extend_descriptors,
   void *handler_arg
+ * @brief Allocates a chunk of memory of at least @a size bytes from the
+ * red-black tree heap @a control.
+ * The chunk begin is aligned by the value specified in
+ * rtems_rbheap_initialize().
+ * @param[in] size The requested chunk size in bytes.
+ * @retval NULL Not enough free space in the heap.
+ * @retval otherwise Pointer to allocated chunk of memory.
 void *rtems_rbheap_allocate(rtems_rbheap_control *control, size_t size);
+ * @brief Frees a chunk of memory @a ptr allocated from the red-black tree heap
+ * @a control.
+ * @param[in] ptr The pointer to the chunk of memory.
+ * @retval RTEMS_INVALID_ID The chunk of memory is not a valid chunk in the
+ * red-black tree heap.
+ * @retval RTEMS_INCORRECT_STATE The chunk of memory is not in the right state.
 rtems_status_code rtems_rbheap_free(rtems_rbheap_control *control, void *ptr);
-static inline rtems_chain_control *rtems_rbheap_get_pool_chain(
+static inline rtems_chain_control *rtems_rbheap_get_free_descriptor_chain(
-  return &control->pool_chain;
+  return &control->free_descriptor_chain;
-static inline void rtems_rbheap_set_extend_page_pool(
+static inline void rtems_rbheap_add_to_free_descriptor_chain(
+  rtems_rbheap_chunk *chunk
-  control->extend_page_pool = extend_page_pool;
+  rtems_chain_control *chain = rtems_rbheap_get_free_descriptor_chain(control);
+  rtems_chain_prepend_unprotected(chain, &chunk->chain_node);
+static inline void rtems_rbheap_set_extend_descriptors(
+  rtems_rbheap_control *control,
+  control->extend_descriptors = extend_descriptors;
 static inline void *rtems_rbheap_get_handler_arg(
@@ -107,20 +182,28 @@ static inline void rtems_rbheap_set_handler_arg(
   control->handler_arg = handler_arg;
-void rtems_rbheap_extend_page_pool_never(rtems_rbheap_control *control);
+ * @brief Chunk descriptor extend handler that does nothing.
+void rtems_rbheap_extend_descriptors_never(rtems_rbheap_control *control);
-void rtems_rbheap_extend_page_pool_with_malloc(rtems_rbheap_control *control);
+ * @brief Chunk descriptor extend handler that uses malloc().
+void rtems_rbheap_extend_descriptors_with_malloc(
 /* Private API */
-#define rtems_rbheap_page_of_node(node) \
-  rtems_rbtree_container_of(node, rtems_rbheap_page, tree_node)
+#define rtems_rbheap_chunk_of_node(node) \
+  rtems_rbtree_container_of(node, rtems_rbheap_chunk, tree_node)
-static inline bool rtems_rbheap_is_page_free(const rtems_rbheap_page *page)
+static inline bool rtems_rbheap_is_chunk_free(const rtems_rbheap_chunk *chunk)
-  return !rtems_chain_is_node_off_chain(&page->chain_node);
+  return !rtems_chain_is_node_off_chain(&chunk->chain_node);
 #ifdef __cplusplus
diff --git a/cpukit/sapi/src/rbheap.c b/cpukit/sapi/src/rbheap.c
index 7986325..c527c52 100644
--- a/cpukit/sapi/src/rbheap.c
+++ b/cpukit/sapi/src/rbheap.c
@@ -28,96 +28,96 @@
-static uintptr_t align_up(uintptr_t page_alignment, uintptr_t value)
+static uintptr_t align_up(uintptr_t alignment, uintptr_t value)
-  uintptr_t excess = value % page_alignment;
+  uintptr_t excess = value % alignment;
   if (excess > 0) {
-    value += page_alignment - excess;
+    value += alignment - excess;
   return value;
-static uintptr_t align_down(uintptr_t page_alignment, uintptr_t value)
+static uintptr_t align_down(uintptr_t alignment, uintptr_t value)
   return value - excess;
-static int page_compare(const rtems_rbtree_node *a, const rtems_rbtree_node *b)
+static int chunk_compare(const rtems_rbtree_node *a, const rtems_rbtree_node *b)
-  const rtems_rbheap_page *left = rtems_rbheap_page_of_node(a);
-  const rtems_rbheap_page *right = rtems_rbheap_page_of_node(b);
+  const rtems_rbheap_chunk *left = rtems_rbheap_chunk_of_node(a);
+  const rtems_rbheap_chunk *right = rtems_rbheap_chunk_of_node(b);
   return (int) (left->begin - right->begin);
-static rtems_rbheap_page *get_page(rtems_rbheap_control *control)
+static rtems_rbheap_chunk *get_chunk(rtems_rbheap_control *control)
-  rtems_chain_control *pool_chain = &control->pool_chain;
-  rtems_chain_node *page = rtems_chain_get(pool_chain);
+  rtems_chain_control *free_descriptor_chain = &control->free_descriptor_chain;
+  rtems_chain_node *chunk = rtems_chain_get_unprotected(free_descriptor_chain);
-  if (page == NULL) {
-    (*control->extend_page_pool)(control);
-    page = rtems_chain_get(pool_chain);
+  if (chunk == NULL) {
+    (*control->extend_descriptors)(control);
+    chunk = rtems_chain_get_unprotected(free_descriptor_chain);
-  return (rtems_rbheap_page *) page;
+  return (rtems_rbheap_chunk *) chunk;
 static void add_to_chain(
   rtems_chain_control *chain,
-  rtems_rbheap_page *page
-  rtems_chain_prepend_unprotected(chain, &page->chain_node);
 static void insert_into_tree(
   rtems_rbtree_control *tree,
-  _RBTree_Insert_unprotected(tree, &page->tree_node);
+  _RBTree_Insert_unprotected(tree, &chunk->tree_node);
   void *area_begin,
   void *handler_arg
   rtems_status_code sc = RTEMS_SUCCESSFUL;
-  if (page_alignment > 0) {
+  if (alignment > 0) {
     uintptr_t begin = (uintptr_t) area_begin;
     uintptr_t end = begin + area_size;
-    uintptr_t aligned_begin = align_up(page_alignment, begin);
-    uintptr_t aligned_end = align_down(page_alignment, end);
+    uintptr_t aligned_begin = align_up(alignment, begin);
+    uintptr_t aligned_end = align_down(alignment, end);
     if (begin < end && begin <= aligned_begin && aligned_begin < aligned_end) {
       rtems_chain_control *free_chain = &control->free_chain;
-      rtems_rbtree_control *page_tree = &control->page_tree;
-      rtems_rbheap_page *first = NULL;
+      rtems_rbtree_control *chunk_tree = &control->chunk_tree;
+      rtems_rbheap_chunk *first = NULL;
       rtems_chain_initialize_empty(free_chain);
-      rtems_chain_initialize_empty(&control->pool_chain);
-      rtems_rbtree_initialize_empty(page_tree, page_compare, true);
-      control->page_alignment = page_alignment;
+      rtems_chain_initialize_empty(&control->free_descriptor_chain);
+      rtems_rbtree_initialize_empty(chunk_tree, chunk_compare, true);
+      control->alignment = alignment;
-      first = get_page(control);
+      first = get_chunk(control);
       if (first != NULL) {
         first->begin = aligned_begin;
         first->size = aligned_end - aligned_begin;
         add_to_chain(free_chain, first);
-        insert_into_tree(page_tree, first);
+        insert_into_tree(chunk_tree, first);
       } else {
         sc = RTEMS_NO_MEMORY;
@@ -131,20 +131,20 @@ rtems_status_code rtems_rbheap_initialize(
   return sc;
-static rtems_rbheap_page *search_free_page(
+static rtems_rbheap_chunk *search_free_chunk(
   rtems_chain_control *free_chain,
   size_t size
   rtems_chain_node *current = rtems_chain_first(free_chain);
   const rtems_chain_node *tail = rtems_chain_tail(free_chain);
-  rtems_rbheap_page *big_enough = NULL;
+  rtems_rbheap_chunk *big_enough = NULL;
   while (current != tail && big_enough == NULL) {
-    rtems_rbheap_page *free_page = (rtems_rbheap_page *) current;
+    rtems_rbheap_chunk *free_chunk = (rtems_rbheap_chunk *) current;
-    if (free_page->size >= size) {
-      big_enough = free_page;
+    if (free_chunk->size >= size) {
+      big_enough = free_chunk;
     current = rtems_chain_next(current);
@@ -157,33 +157,33 @@ void *rtems_rbheap_allocate(rtems_rbheap_control *control, size_t size)
   void *ptr = NULL;
-  uintptr_t page_alignment = control->page_alignment;
-  uintptr_t aligned_size = align_up(page_alignment, size);
+  uintptr_t alignment = control->alignment;
+  uintptr_t aligned_size = align_up(alignment, size);
   if (size > 0 && size <= aligned_size) {
-    rtems_rbheap_page *free_page = search_free_page(free_chain, aligned_size);
+    rtems_rbheap_chunk *free_chunk = search_free_chunk(free_chain, aligned_size);
-    if (free_page != NULL) {
-      uintptr_t free_size = free_page->size;
+    if (free_chunk != NULL) {
+      uintptr_t free_size = free_chunk->size;
       if (free_size > aligned_size) {
-        rtems_rbheap_page *new_page = get_page(control);
+        rtems_rbheap_chunk *new_chunk = get_chunk(control);
-        if (new_page != NULL) {
+        if (new_chunk != NULL) {
           uintptr_t new_free_size = free_size - aligned_size;
-          free_page->size = new_free_size;
-          new_page->begin = free_page->begin + new_free_size;
-          new_page->size = aligned_size;
-          rtems_chain_set_off_chain(&new_page->chain_node);
-          insert_into_tree(page_tree, new_page);
-          ptr = (void *) new_page->begin;
+          free_chunk->size = new_free_size;
+          new_chunk->begin = free_chunk->begin + new_free_size;
+          new_chunk->size = aligned_size;
+          rtems_chain_set_off_chain(&new_chunk->chain_node);
+          insert_into_tree(chunk_tree, new_chunk);
+          ptr = (void *) new_chunk->begin;
       } else {
-        rtems_chain_extract_unprotected(&free_page->chain_node);
-        rtems_chain_set_off_chain(&free_page->chain_node);
-        ptr = (void *) free_page->begin;
+        rtems_chain_extract_unprotected(&free_chunk->chain_node);
+        rtems_chain_set_off_chain(&free_chunk->chain_node);
+        ptr = (void *) free_chunk->begin;
@@ -191,38 +191,38 @@ void *rtems_rbheap_allocate(rtems_rbheap_control *control, size_t size)
   return ptr;
-#define NULL_PAGE rtems_rbheap_page_of_node(NULL)
+#define NULL_PAGE rtems_rbheap_chunk_of_node(NULL)
-static rtems_rbheap_page *find(rtems_rbtree_control *page_tree, uintptr_t key)
+static rtems_rbheap_chunk *find(rtems_rbtree_control *chunk_tree, uintptr_t key)
-  rtems_rbheap_page page = { .begin = key };
+  rtems_rbheap_chunk chunk = { .begin = key };
-  return rtems_rbheap_page_of_node(
-    _RBTree_Find_unprotected(page_tree, &page.tree_node)
+  return rtems_rbheap_chunk_of_node(
+    _RBTree_Find_unprotected(chunk_tree, &chunk.tree_node)
-static rtems_rbheap_page *get_next(
-  const rtems_rbtree_control *page_tree,
-  const rtems_rbheap_page *page,
+static rtems_rbheap_chunk *get_next(
+  const rtems_rbtree_control *chunk_tree,
+  const rtems_rbheap_chunk *chunk,
   RBTree_Direction dir
-    _RBTree_Next_unprotected(page_tree, &page->tree_node, dir)
+    _RBTree_Next_unprotected(chunk_tree, &chunk->tree_node, dir)
 static void check_and_merge(
-  rtems_rbtree_control *page_tree,
-  rtems_rbheap_page *a,
+  rtems_rbtree_control *chunk_tree,
+  rtems_rbheap_chunk *a,
-  if (b != NULL_PAGE && rtems_rbheap_is_page_free(b)) {
+  if (b != NULL_PAGE && rtems_rbheap_is_chunk_free(b)) {
     if (b->begin < a->begin) {
-      rtems_rbheap_page *t = a;
+      rtems_rbheap_chunk *t = a;
       a = b;
       b = t;
@@ -231,47 +231,48 @@ static void check_and_merge(
     a->size += b->size;
     rtems_chain_extract_unprotected(&b->chain_node);
     add_to_chain(free_chain, b);
-    _RBTree_Extract_unprotected(page_tree, &b->tree_node);
+    _RBTree_Extract_unprotected(chunk_tree, &b->tree_node);
-  rtems_chain_control *free_chain = &control->free_chain;
-  rtems_rbheap_page *page = find(page_tree, (uintptr_t) ptr);
-  if (page != NULL_PAGE) {
-    if (!rtems_rbheap_is_page_free(page)) {
-      rtems_rbheap_page *pred = get_next(page_tree, page, RBT_LEFT);
-      rtems_rbheap_page *succ = get_next(page_tree, page, RBT_RIGHT);
+  if (ptr != NULL) {
+    rtems_chain_control *free_chain = &control->free_chain;
+    rtems_rbheap_chunk *chunk = find(chunk_tree, (uintptr_t) ptr);
+    if (chunk != NULL_PAGE) {
+      if (!rtems_rbheap_is_chunk_free(chunk)) {
+        rtems_rbheap_chunk *pred = get_next(chunk_tree, chunk, RBT_LEFT);
+        rtems_rbheap_chunk *succ = get_next(chunk_tree, chunk, RBT_RIGHT);
-      check_and_merge(free_chain, page_tree, page, succ);
-      add_to_chain(free_chain, page);
-      check_and_merge(free_chain, page_tree, page, pred);
+        check_and_merge(free_chain, chunk_tree, chunk, succ);
+        add_to_chain(free_chain, chunk);
+        check_and_merge(free_chain, chunk_tree, chunk, pred);
+      } else {
+        sc = RTEMS_INCORRECT_STATE;
     } else {
-      sc = RTEMS_INCORRECT_STATE;
+      sc = RTEMS_INVALID_ID;
-  } else {
-    sc = RTEMS_INVALID_ID;
   return sc;
   /* Do nothing */
+void rtems_rbheap_extend_descriptors_with_malloc(rtems_rbheap_control *control)
-  rtems_rbheap_page *page = malloc(sizeof(*page));
-  if (page != NULL) {
-    rtems_chain_control *pool_chain = rtems_rbheap_get_pool_chain(control);
+  rtems_rbheap_chunk *chunk = malloc(sizeof(*chunk));
-    add_to_chain(pool_chain, page);
+  if (chunk != NULL) {
+    rtems_rbheap_add_to_free_descriptor_chain(control, chunk);
diff --git a/testsuites/libtests/rbheap01/init.c b/testsuites/libtests/rbheap01/init.c
index a66cc24..171cfd2 100644
--- a/testsuites/libtests/rbheap01/init.c
+++ b/testsuites/libtests/rbheap01/init.c
@@ -27,26 +27,26 @@
 static char area [PAGE_SIZE * PAGE_COUNT + PAGE_SIZE - 1];
-static rtems_rbheap_page pages [PAGE_COUNT];
+static rtems_rbheap_chunk chunks [PAGE_COUNT];
-static void extend_page_pool(rtems_rbheap_control *control)
+static void extend_descriptors(rtems_rbheap_control *control)
-  rtems_rbheap_set_extend_page_pool(
+  rtems_rbheap_set_extend_descriptors(
     control,
-    rtems_rbheap_extend_page_pool_never
+    rtems_rbheap_extend_descriptors_never
   rtems_chain_initialize(
-    pool_chain,
-    pages,
+    chain,
+    chunks,
     PAGE_COUNT,
-    sizeof(pages [0])
+    sizeof(chunks [0])
-static uintptr_t idx(const rtems_rbheap_page *page)
+static uintptr_t idx(const rtems_rbheap_chunk *chunk)
   uintptr_t base = (uintptr_t) area;
   uintptr_t excess = base % PAGE_SIZE;
@@ -55,7 +55,7 @@ static uintptr_t idx(const rtems_rbheap_page *page)
     base += PAGE_SIZE - excess;
-  return (page->begin - base) / PAGE_SIZE;
+  return (chunk->begin - base) / PAGE_SIZE;
 typedef struct {
@@ -63,22 +63,22 @@ typedef struct {
   const uintptr_t *index_end;
   const bool *free_current;
   const bool *free_end;
-} page_visitor_context;
+} chunk_visitor_context;
-static bool page_visitor(
+static bool chunk_visitor(
   const RBTree_Node *node,
   RBTree_Direction dir,
   void *visitor_arg
-  rtems_rbheap_page *page = rtems_rbheap_page_of_node(node);
-  page_visitor_context *context = visitor_arg;
+  rtems_rbheap_chunk *chunk = rtems_rbheap_chunk_of_node(node);
+  chunk_visitor_context *context = visitor_arg;
   rtems_test_assert(context->index_current != context->index_end);
   rtems_test_assert(context->free_current != context->free_end);
-  rtems_test_assert(idx(page) == *context->index_current);
-  rtems_test_assert(rtems_rbheap_is_page_free(page) == *context->free_current);
+  rtems_test_assert(idx(chunk) == *context->index_current);
+  rtems_test_assert(rtems_rbheap_is_chunk_free(chunk) == *context->free_current);
   ++context->index_current;
   ++context->free_current;
@@ -86,7 +86,7 @@ static bool page_visitor(
   return false;
-static void test_init_page_alignment(void)
+static void test_init_chunk_alignment(void)
   rtems_rbheap_control control;
@@ -96,7 +96,7 @@ static void test_init_page_alignment(void)
     area,
     sizeof(area),
     0,
-    extend_page_pool,
+    extend_descriptors,
     NULL
   rtems_test_assert(sc == RTEMS_INVALID_NUMBER);
@@ -112,7 +112,7 @@ static void test_init_begin_greater_than_end(void)
     (void *) PAGE_SIZE,
     (uintptr_t) -PAGE_SIZE,
     PAGE_SIZE,
-    extend_page_pool,
     NULL
   rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
@@ -128,7 +128,7 @@ static void test_init_begin_greater_than_aligned_begin(void)
     (void *) -(PAGE_SIZE / 2),
     PAGE_SIZE,
     PAGE_SIZE,
-    extend_page_pool,
     NULL
@@ -144,13 +144,13 @@ static void test_init_aligned_begin_greater_than_aligned_end(void)
     (void *) PAGE_SIZE,
     PAGE_SIZE / 2,
     PAGE_SIZE,
-    extend_page_pool,
     NULL
-static void test_init_empty_page_pool(void)
+static void test_init_empty_descriptors(void)
@@ -160,13 +160,13 @@ static void test_init_empty_page_pool(void)
     (void *) PAGE_SIZE,
     PAGE_SIZE,
     PAGE_SIZE,
-    rtems_rbheap_extend_page_pool_never,
+    rtems_rbheap_extend_descriptors_never,
     NULL
   rtems_test_assert(sc == RTEMS_NO_MEMORY);
-static void test_page_tree(
+static void test_chunk_tree(
   const rtems_rbheap_control *control,
   const uintptr_t *index_begin,
   const uintptr_t *index_end,
@@ -174,7 +174,7 @@ static void test_page_tree(
-  page_visitor_context context = {
+  chunk_visitor_context context = {
     .index_current = index_begin,
     .index_end = index_end,
     .free_current = free_begin,
@@ -182,15 +182,15 @@ static void test_page_tree(
   _RBTree_Iterate_unprotected(
-    &control->page_tree,
+    &control->chunk_tree,
     RBT_RIGHT,
-    page_visitor,
+    chunk_visitor,
     &context
 #define TEST_PAGE_TREE(control, indices, frees) \
-  test_page_tree( \
+  test_chunk_tree( \
     control, \
     indices, \
     &indices [sizeof(indices) / sizeof(indices [0])], \
@@ -214,7 +214,7 @@ static void test_init_successful(rtems_rbheap_control *control)
     area,
     sizeof(area),
     PAGE_SIZE,
-    extend_page_pool,
     NULL
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
@@ -276,7 +276,7 @@ static void test_alloc_zero(void)
   TEST_PAGE_TREE(&control, indices, frees);
-static void test_alloc_huge_page(void)
+static void test_alloc_huge_chunk(void)
   static const uintptr_t indices [] = {
     0
@@ -296,7 +296,7 @@ static void test_alloc_huge_page(void)
-static void test_alloc_one_page(void)
+static void test_alloc_one_chunk(void)
   static const uintptr_t indices_0 [] = {
     0
@@ -328,7 +328,7 @@ static void test_alloc_one_page(void)
   TEST_PAGE_TREE(&control, indices_1, frees_1);
-static void test_alloc_many_pages(void)
+static void test_alloc_many_chunks(void)
     0,
@@ -385,7 +385,7 @@ static void test_alloc_many_pages(void)
-static void test_free_invalid(void)
+static void test_free_null(void)
@@ -393,6 +393,17 @@ static void test_free_invalid(void)
   test_init_successful(&control);
   sc = rtems_rbheap_free(&control, NULL);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+static void test_free_invalid(void)
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  rtems_rbheap_control control;
+  test_init_successful(&control);
+  sc = rtems_rbheap_free(&control, (void *) 1);
   rtems_test_assert(sc == RTEMS_INVALID_ID);
@@ -539,16 +550,17 @@ static void Init(rtems_task_argument arg)
   puts("\n\n*** TEST RBHEAP 1 ***");
-  test_init_page_alignment();
+  test_init_chunk_alignment();
   test_init_begin_greater_than_end();
   test_init_begin_greater_than_aligned_begin();
   test_init_aligned_begin_greater_than_aligned_end();
-  test_init_empty_page_pool();
+  test_init_empty_descriptors();
   test_alloc_and_free_one();
   test_alloc_zero();
-  test_alloc_huge_page();
-  test_alloc_one_page();
-  test_alloc_many_pages();
+  test_alloc_huge_chunk();
+  test_alloc_one_chunk();
+  test_alloc_many_chunks();
+  test_free_null();
   test_free_invalid();
   test_free_double();
   test_free_merge_left_or_right(true);
1.6.4.2
More information about the rtems-devel mailing list
