body functions
Ralf Corsepius
ralf.corsepius at rtems.org
Thu Dec 8 22:01:33 CST 2011
On 12/08/2011 10:24 PM, Chris Johns wrote:
> On 9/12/11 4:25 AM, Ralf Corsepius wrote:
>> RTEMS contains a set of functions which are implemented as both #defines
>> and as normal functions (aka. body functions)[1].
>> This raises a couple implementation problems in RTEMS esp, wrt.
>> using the compiler to enforce stricter coding standards.
>> As things currently appear to me, the only usage of these "body
>> functions" is supporting GNAT/Ada, while no pure C application nor RTEMS
>> itself uses them - Is this understanding correct?
> I am not 100% certain and I agree it seems to be a compiler trick to
> make them work. My understanding is given no references are made these
> functions are never linked by a C program.
>> Fact seems to be something should be done to get them "out of way" of
>> the C-part of RTEMS to simplify improving the coding quality of RTEMS[2].
> Are the warnings just about these files or other interactions else where ?
The problem is the way they currently are implemented, which currently
condenses to this:
public.h:
#define foo(arg1, arg2) foomacro
implementation.c:
#include <public.h>
#undef foo
arg0_t foo( arg1_t arg1, arg2_t arg2)
[foobody]
=> Will raise a missing-prototype "foo" warning.
body-usecase.c:
#include <public.h>
#undef foo
foo(1,2)
=> Disables the compiler's argument checking
== unsafe code (e.g. arg type mismatches will not be diagnosed)
macro-usecase.c:
#include <public.h>
foo(1,2)
>> I am not sure what do ... crude, uncooked ideas would be:
>> - Split these functions out into a separate library?
>> - Move the "body functions" to cpukit/libgnat?
> Would this also be an issue for other languages ?
Joel says so and I am inclined to agree, because many "non-c" languages
can't cope with #defines.
However, I am not sure why this issue should be limited to only these
ca. 10 macros and would not affect the way higher number of "other
macros" in RTEMS.
>> - Eliminate the #defines and supply C-body functions only?
> This would effect performance.
Well, I'd expect this claim to apply to some of these functions, but not
to all.
> - Rename the macro in the specific file and use it wrapped in the
> function version. This way it avoids any skew type issues if
> the implementation changes.
Yep, that could work.
On the implementation side, the key to resolving this issue to me seems
to be "removing the #undefs" and to use strictly separated symbols.
>> It's not clear to me which of these ideas are useful or would really
>> make sense.
> How does moving it to a library help ?
It would be a completely separate 2nd implementation, in parallel to the
original RTEMS-c-libraries.
In case of Gnat/Ada (And libgnat), this would defacto entirely remove
the "body functions" from c-RTEMS and make these a Gnat/Ada
implementation detail.
Problem would be keeping the "2nd implementation" in sync with the
primary implementation, but it at least would keep the primary
implementation "clean".
> Would the warning move with the
> code to the library ?
... Depends on how this would be implemented,
>> [2] This weeks's PR and patch flood has its origin in me compiling RTEMS
>> with very aggressive GCC-warning flags.
>> Initial result: >5000 warnings per BSP, with several quite serious ones
>> amongst them.
> Ouch.
Yeah, I had expected to be flooded with GCC warnings, but the amount of
warnings GCC confronted me with, was beyond expectaction - I can't deny
to be shocked and can't avoid to find this embarrassing.
#1 mistake of serious bugs seems to be not having enforced strict
prototyping (combined with having banned local redeclarations) and
excessive use of defines.
I plan to make some of the these flags I am currently experimenting
with, default in CVS-HEAD, after having moved the biggest road-blocks
out of the way (The body functions are one of these).
Ralf
More information about the rtems-devel
