[Bug 1802] smp support for i386
bugzilla-daemon at rtems.org
Fri May 20 11:52:10 CDT 2011
https://www.rtems.org/bugzilla/show_bug.cgi?id=1802
Gedare <giddyup44 at yahoo.com> changed:
What |Removed |Added
CC| |giddyup44 at yahoo.com
--- Comment #1 from Gedare <giddyup44 at yahoo.com> 2011-05-20 11:52:10 CDT ---
why not integrate appcpustart.S with start.S as is done with the leon?
+pc386_delay:
+_pc386_delay:
IIRC this type of routine was the reason for an rtems_bsp_delay in the first
place.
smp-imps.c:
+#define __RTEMS_VIOLATE_KERNEL_VISIBILITY__
What is this for?
+/* base address of applciation processor reset code at 0x70000 */
typo s/applciation/application
+extern char _binary_appstart_bin_start[];
+extern char _binary_appstart_bin_size[];
+extern void _pc386_delay(void);
These should probably be declared in smp-imps.h?
There are a number of printks that should be #ifdef'd out for production.
+int
+imps_probe(void)
namespace?
+ * RTEMS SMP BSP Support
Everything below / including this should probably go in separate file(s)
smp-imps.h:
Are the exported globals required?
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
