[Bug 1534] New: TFTP file system mount configuration
bugzilla-daemon at rtems.org
Fri May 28 17:17:54 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1534
Summary: TFTP file system mount configuration
Product: RTEMS
Version: 4.10
Platform: All
OS/Version: RTEMS
Status: ASSIGNED
Severity: enhancement
Priority: P3
Component: filesystem
AssignedTo: chrisj at rtems.org
ReportedBy: chrisj at rtems.org
Currently the TFTP file system is fixed to /TFTP and under that is the server
name and the file. This fixed format does not sit well with a mount
call/command that allows the file system to be under the control of the user.
This enhancement is to change the file system to allow mounting any where in
the file system and to have the device or source field be the host plus any
path. For example the mount command in the shell could be:
$ mount -t tftpfs rtems.org:/ftp/pub/rtems/SOURCE /source
This comment mounts the RTEMS source directory if rtems.org allowed TFTP access
(which it does not) and source packages could be read from the local /source
directory. For example 'cat /source/README'.
The current behavior could be achieved with the following shell commands:
$ mkdir /TFTP
$ mkdir /TFTP/10.10.10.10
$ mount -t tftpfs 10.10.10.10:/ /TFTP/10.10.10.10
with the difference being you need a mount for each server.
This change will also allow host names rather than just IP addresses.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
