[Bug 1533] New: TFTP File system open does not set errno
bugzilla-daemon at rtems.org
Fri May 28 17:07:29 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1533
Summary: TFTP File system open does not set errno
Product: RTEMS
Version: 4.10
Platform: All
OS/Version: RTEMS
Status: ASSIGNED
Severity: normal
Priority: P3
Component: filesystem
AssignedTo: chrisj at rtems.org
ReportedBy: chrisj at rtems.org
The TFTP file system code does not set errno in open. It returns the errno
error code rather than setting errno and returning 0 or 1 for an error. This
results in the file being opened with no worker so set to NULL and a machine
check in read.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
