[Bug 1532] Review Request -- First Test of Loading tarfile info IMFS
bugzilla-daemon at rtems.org
Thu May 27 23:08:50 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1532
--- Comment #5 from Ralf Corsepius <ralf.corsepius at rtems.org> 2010-05-27 23:08:48 ---
> One question about 'aclocal/canonicalize-tools.m4' and 'aclocal' dirs. These
> files are really important, not only in the RTEMS source tree but outside. I
> took a number of these files to create autotools apps outside the source tree
> and without these macro files it would have been really difficult.
This should not be the case. Using vanilla autoconf/automake macros should
suffice.
> I would like
> to make a push to all external apps being autotools based for 4.11 so this
> directory will be even more important. Given there are a number of 'aclocal'
> directories in the tree, which is the master copy ?
There is no master.
They are "all equal" and "independent", with some *.m4 files happening to be
identical :)
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
