[Bug 1510] New: Wrong memory allocation check in example
bugzilla-daemon at rtems.org
Wed May 5 15:39:22 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1510
Summary: Wrong memory allocation check in example
Product: RTEMS
Version: unknown
Platform: All
URL: http://rtems.com/onlinedocs/doc-current/share/rtems/ht
ml/c_user/c_user00513.html
OS/Version: RTEMS
Status: NEW
Severity: trivial
Priority: P3
Component: doc
AssignedTo: joel.sherrill at oarcorp.com
ReportedBy: alin.codejunkie at gmail.com
CC: chrisj at rtems.org
The memory allocation check in this example is incorrect
http://rtems.com/onlinedocs/doc-current/share/rtems/html/c_user/c_user00513.html
foo* bar = malloc (sizeof (foo));
if (!foo)
return -1;
You should have:
if (!bar)
return -1;
Since bar is the pointer to the allocated memory
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
