[Bug 1560] sparc64 [1/5]: _Objects_Extend_information improper alignment for 64-bit targets
bugzilla-daemon at rtems.org
Wed Jun 23 16:36:34 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1560
--- Comment #6 from Joel Sherrill <joel.sherrill at oarcorp.com> 2010-06-23 16:36:33 CDT ---
I think some of the allocation is going to have to be broken into pieces to
make sp70 run. Coverity found an issue which I finally got a test case to
force. It is when you are reusing a hole in the middle. That means you don't
"realloc" the local tables or arrays.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
