[Bug 1532] Review Request -- First Test of Loading tarfile info IMFS
bugzilla-daemon at rtems.org
Wed Jun 9 07:04:31 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1532
--- Comment #12 from Joel Sherrill <joel.sherrill at oarcorp.com> 2010-06-09 07:04:30 ---
Chris,
Please look at the attached patch. It seems to work ok for untar from memory.
Then I test untar from file. The test sequence for that part is:
+ copy memory image to /test.tar
+ mkdir /dest
+ chdir /dest
+ untar from file /test.tar
+ Then it uses test_cat to display the files untar'ed. That gives an
error.
Any insight would be appreciated.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
