[Bug 1544] New: 4.10 BLOCKER -- mpc55xxevb BSP does not build
bugzilla-daemon at rtems.org
Thu Jun 3 12:17:27 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1544
Summary: 4.10 BLOCKER -- mpc55xxevb BSP does not build
Product: RTEMS
Version: 4.10 (CVS)
Platform: All
OS/Version: RTEMS
Status: NEW
Severity: blocker
Priority: P1
Component: bsps
AssignedTo: sebastian.huber at embedded-brains.de
ReportedBy: joel.sherrill at oarcorp.com
CC: chrisj at rtems.org
This broke with the recent mount changes. It is the only issue I know of
stopping me from branching.
../../../../../../../../rtems/c/src/lib/libbsp/powerpc/mpc55xxevb/tests/tests.c:
In function 'test_mpc55xx_intc':
../../../../../../../../rtems/c/src/lib/libbsp/powerpc/mpc55xxevb/tests/tests.c:689:
warning: implicit declaration of function
'BSP_install_rtems_shared_irq_handler'
warning: nested extern declaration of 'BSP_install_rtems_shared_irq_handler'
At top level:
../../../../../../../../rtems/c/src/lib/libbsp/powerpc/mpc55xxevb/tests/tests.c:70:
warning: 'test_mpc55xx_dspi_transfer_mode' defined but not used
../../../../../../../../rtems/c/src/lib/libbsp/powerpc/mpc55xxevb/tests/tests.c:556:
warning: 'inbuf' defined but not used
../../../../../../../../rtems/c/src/lib/libbsp/powerpc/mpc55xxevb/tests/tests.c:557:
warning: 'outbuf' defined but not used
../../../../../../../../rtems/c/src/lib/libbsp/powerpc/mpc55xxevb/startup/sd-card-init.c:102:
error: 'msdos_ops' undeclared here (not in a function)
powerpc-rtems4.10-ar cru libbspstart.a start.o rtems_crti.o
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
