[Bug 1692] New: rtems_libio_is_valid_perms is broken
bugzilla-daemon at rtems.org
Fri Aug 27 12:18:23 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1692
Summary: rtems_libio_is_valid_perms is broken
Product: RTEMS
Version: HEAD
Platform: All
OS/Version: RTEMS
Status: NEW
Severity: normal
Priority: P3
Component: filesystem
AssignedTo: chrisj at rtems.org
ReportedBy: joel.sherrill at oarcorp.com
Coverity pointed out that the implementation evaluated to a constant. This
impacted the implementation of this method. In discussing the fix, it was
pointed out that when checking the result of this test, we should return EPERM
not EIO.
This was pointed out by at least the following CIDs.
http://scan2.coverity.com:9104/cov.cgi?cid=54
http://scan2.coverity.com:9104/cov.cgi?cid=55
http://scan2.coverity.com:9104/cov.cgi?cid=56
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
