[Bug 1691] sparc64 usiii MMU trap handler crash
bugzilla-daemon at rtems.org
Thu Aug 26 21:05:13 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1691
Chris Johns <chrisj at rtems.org> changed:
What |Removed |Added
CC| |chrisj at rtems.org
--- Comment #4 from Chris Johns <chrisj at rtems.org> 2010-08-26 21:05:11 CDT ---
(In reply to comment #4)
> One solution I can think of at the moment is to try to copy more of the
> firmware. I'm not sure exactly how much needs to be copied though, and it would
> be best to determine this amount off-line so that the linker knows about the
> region of code being used. An experimentally derived value of doubling the
> copied space (from 32K to 64K) works on the Simics simulator. The attached
> patch introduces this doubling multiplier in the trap table size to accomplish
> the copying.
As commented in the patch this is a hack. What happens if the firmware is
upgraded and you have a number of different versions operating in the field ?
> Another possible solution would be to install a replacement trap handler,
> perhaps with a jump to the original trap handler (which still exists) in the
> firmware.
If I understand this correctly, you turn the relative address into an absolute
address when the new trap table is installed and call the absolute address
pointing to the firmware ?
> This would have to be done for every trap handler that branches
> outside of the trap table. Since the previous fix works, I did not investigate
> this approach.
Sound like a much better solution.
I do not consider this issue resolved or fixed with the hack installed. Please
consider reopening.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
