[Bug 1681] sparc64 still using _CPU_Interrupt_stack_high in asm
bugzilla-daemon at rtems.org
Fri Aug 20 11:31:07 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1681
--- Comment #4 from Joel Sherrill <joel.sherrill at oarcorp.com> 2010-08-20 11:31:06 CDT ---
(In reply to comment #3)
> This patch was not applied properly. It should also change
> c/src/lib/libcpu/sparc64/shared/score/interrupt.S
I noticed that before I noticed you reopened the PR. Is it OK now?
If so, please close.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
