[Bug 1681] New: sparc64 still using _CPU_Interrupt_stack_high in asm
bugzilla-daemon at rtems.org
Wed Aug 18 14:28:09 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1681
Summary: sparc64 still using _CPU_Interrupt_stack_high in asm
Product: RTEMS
Version: HEAD
Platform: All
OS/Version: RTEMS
Status: NEW
Severity: normal
Priority: P3
Component: libcpu
AssignedTo: joel.sherrill at oarcorp.com
ReportedBy: giddyup44 at yahoo.com
Created an attachment (id=1023)
--> (https://www.rtems.org/bugzilla/attachment.cgi?id=1023)
Patch.
With the percpu patch, ASM uses INTERRUPT_STACK_HIGH instead of
_CPU_Interrupt_stack_high. The sparc64 was still using the old variable, which
was declared in its cpu.h file.
I've attached a patch to comment out the declaration and switch to using
INTERRUPT_STACK_HIGH. Since percpu is still an open PR, I'm also going to link
this PR to it.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
