[Bug 1677] Assertion at IMFS_create_node
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Wed Aug 18 06:40:26 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1677
--- Comment #6 from Joel Sherrill <joel.sherrill at oarcorp.com> 2010-08-18 06:40:25 CDT ---
Please make sure your tree is up to date.  I know I test very frequently
on sparc/sis but usually catch the coverage on pc386 about once a week.
(In reply to comment #5)
> The fix was provided on 1679 and is:
> (rtems-cvs-20100814)
> line 67:
>   if ( type == IMFS_DIRECTORY ) {
>     rtems_chain_initialize_empty(&node->info.directory.Entries);
>   } else if ( type == IMFS_HARD_LINK ) {
>     node->info.hard_link.link_node = info->hard_link.link_node;
>   } else if ( type == IMFS_SYM_LINK ) {
>     node->info.sym_link.name = info->sym_link.name;
>   } else if ( type == IMFS_DEVICE ) {
>     node->info.device.major = info->device.major;
>     node->info.device.minor = info->device.minor;
>   } else if ( type == IMFS_LINEAR_FILE ) {
>     node->info.linearfile.size      = 0;
>     node->info.linearfile.direct    = 0;
>     if ( type == IMFS_MEMORY_FILE ) {   // bug!!!
>       node->info.file.size            = 0;
>       node->info.file.indirect        = 0;
>       node->info.file.doubly_indirect = 0;
>       node->info.file.triply_indirect = 0;
>   } else if ( type == IMFS_FIFO ) {
>     node->info.fifo.pipe = NULL;
>   } else {
>     IMFS_assert(0);
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
