[Bug 1677] Assertion at IMFS_create_node
bugzilla-daemon at rtems.org
Wed Aug 18 04:47:00 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1677
Chris Johns <chrisj at rtems.org> changed:
What |Removed |Added
Status|NEW |ASSIGNED
CC| |chrisj at rtems.org
--- Comment #5 from Chris Johns <chrisj at rtems.org> 2010-08-18 04:46:59 CDT ---
The fix was provided on 1679 and is:
(rtems-cvs-20100814)
line 67:
if ( type == IMFS_DIRECTORY ) {
rtems_chain_initialize_empty(&node->info.directory.Entries);
} else if ( type == IMFS_HARD_LINK ) {
node->info.hard_link.link_node = info->hard_link.link_node;
} else if ( type == IMFS_SYM_LINK ) {
node->info.sym_link.name = info->sym_link.name;
} else if ( type == IMFS_DEVICE ) {
node->info.device.major = info->device.major;
node->info.device.minor = info->device.minor;
} else if ( type == IMFS_LINEAR_FILE ) {
node->info.linearfile.size = 0;
node->info.linearfile.direct = 0;
if ( type == IMFS_MEMORY_FILE ) { // bug!!!
node->info.file.size = 0;
node->info.file.indirect = 0;
node->info.file.doubly_indirect = 0;
node->info.file.triply_indirect = 0;
} else if ( type == IMFS_FIFO ) {
node->info.fifo.pipe = NULL;
} else {
IMFS_assert(0);
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
