[Bug 1673] Chain append and prepend with empty check
bugzilla-daemon at rtems.org
Tue Aug 17 12:04:24 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1673
--- Comment #4 from Peer Stritzinger <peerst at gmail.com> 2010-08-17 12:04:24 CDT ---
(In reply to comment #3)
> (In reply to comment #2)
> > Additionaly I think API calls along the line:
> > rtems_chain_get_with_empty_check() ...
> Do we really need this? chain_get() already returns NULL if the chain is empty.
But I had a different application in mind: notify a producer if you took the
last one from the chain.
So the empty check would be after the last one was taken.
With chain_get there is the question of what is returned.
Because of this it might even make sense to have the
rtems_chain_append_with_notification( chain, node, tid, event)
and
rtems_chain_get_with_notification (chain, tid, event) -> node
functions instead. These were the functions Joel suggested to me in IRC.
Their disadvantage are of course that in theory they are less flexible. But in
practice they encapsulate a very common use case.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
