[Bug 1675] mcf5329 BSP post-link conversion broken
bugzilla-daemon at rtems.org
Tue Aug 17 01:47:06 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1675
--- Comment #8 from Sebastian Huber <sebastian.huber at embedded-brains.de> 2010-08-17 01:47:05 CDT ---
(In reply to comment #5)
> (In reply to comment #4)
> > We should abandon all these make hooks in the long run, since they don't
> > integrate well into Automake and other build systems.
> The hooks are fine with autoconf. I would like to see them stay. They could
> call a script.
If you look at the test suite Makefile.am I think that they don't integrate at
all.
> > It would be better to
> > provide scripts that can be reused more conveniently.
> Moving the logic to a patch is fine if you can solve the problem of managing
> lots of script for lots of BSPs, documenting them, enforcing some sort of
> standard, and creating them for all existing BSPs.
Yes, its a lot of work to convert them for all BSPs. Maintaining lots of
scripts is not different to maintaining lots of hooks. The hooks are not
documented and the hook mechanic also (or did I only find no documentation?).
I guess new RTEMS users will learn this through copy and paste from existing
BSPs.
Basically we only need something that translates an *.exe ELF-file into
something else with name *.ralf.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
