[Bug 1675] mcf5329 BSP post-link conversion broken
bugzilla-daemon at rtems.org
Tue Aug 17 01:14:10 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1675
Ralf Corsepius <ralf.corsepius at rtems.org> changed:
What |Removed |Added
CC| |ralf.corsepius at rtems.org
--- Comment #6 from Ralf Corsepius <ralf.corsepius at rtems.org> 2010-08-17 01:14:08 CDT ---
(In reply to comment #5)
> (In reply to comment #4)
> > We should abandon all these make hooks in the long run, since they don't
> > integrate well into Automake and other build systems.
> The hooks are fine with autoconf. I would like to see them stay. They could
> call a script.
Firstly, we are talking about automake, not autoconf.
Secondly, I hate these hooks.
> > It would be better to
> > provide scripts that can be reused more conveniently.
> Moving the logic to a patch is fine if you can solve the problem of managing
> lots of script for lots of BSPs, documenting them, enforcing some sort of
> standard, and creating them for all existing BSPs.
The point Sebastian has brought up (again), isn't new. It has been haunting
RTEMS for a very long time and reappears every now and then, whenever somebody
is facing the limitations of this approach.
I recall me having proposed to remove the hooks and to replace them with
scripts, many years ago (probably >> 10 years) and me actually having worked on
them, until something was introduced into RTEMS which broke this approach (I
don't recall what it was).
May-be it's time to revisit this issue once again.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
