[Bug 1656] GSoC AIO patch
bugzilla-daemon at rtems.org
Mon Aug 16 13:31:57 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1656
--- Comment #26 from Joel Sherrill <joel.sherrill at oarcorp.com> 2010-08-16 13:31:54 CDT ---
(In reply to comment #25)
> (In reply to comment #19)
> > I noticed that psxenosys broke with this patch. It broke because some
> > of the aio_ routines are implemented but there remain 3 that are not:
> > $ grep ENOSYS aio*
> > aio_cancel.c: rtems_set_errno_and_return_minus_one( ENOSYS );
> > aio_fsync.c: rtems_set_errno_and_return_minus_one( ENOSYS );
> > aio_suspend.c: rtems_set_errno_and_return_minus_one( ENOSYS );
> aio_cancel is being worked on, it's finished but not tested.
> aio_fsync() and aio_suspend are missing because of this
> http://www.rtems.com/wiki/index.php/POSIX_Asynchronous_IO . I see you're the
> last editor of the page.
I think you read too much into that list. :)
I was the author of that page but only in the sense that I took one massively
large "Open Projects" page and dispersed it into individual project files.
The project is to implement aio_ defined in aio.h as specified by the
Open Group. aio_fsync shouldn't be terribly hard to add. I don't
know about aio_suspend().
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
