[Bug 1674] New: doc doesn't build
bugzilla-daemon at rtems.org
Fri Aug 13 11:33:39 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1674
Summary: doc doesn't build
Product: RTEMS
Version: HEAD
Platform: All
OS/Version: RTEMS
Status: NEW
Severity: normal
Priority: P3
Component: doc
AssignedTo: joel.sherrill at oarcorp.com
ReportedBy: giddyup44 at yahoo.com
following the build instructions in the doc/README, the build fails during
'make info' with the following:
rtems/doc/user//dirstat.texi:10: Prev reference to nonexistent node `Chains
Prepend a Node (unprotected)' (perhaps incorrect sectioning?).
rtems/doc/user//chains.texi:833: Next field of node `Chains Prepend a Node' not
pointed to (perhaps incorrect sectioning?).
rtems/doc/user//dirstat.texi:10: This node (Directive Status Codes) has the bad
Prev.
makeinfo: Removing output file `c_user.info' due to errors; use --force to
preserve.
make[1]: *** [c_user.info] Error 1
make[1]: Leaving directory `rtems/doc/user'
make: *** [info-recursive] Error 1
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
