[Bug 1656] GSoC AIO patch
bugzilla-daemon at rtems.org
Fri Aug 13 11:18:12 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1656
--- Comment #13 from Ralf Corsepius <ralf.corsepius at rtems.org> 2010-08-13 11:17:36 CDT ---
(In reply to comment #12)
> I spent the last days redesigning and implementing the whole thing from
> scratch.
I am glad to hear this. Hopefully this will resolve the copyright/licensing
issue Mimicking/copying the API isn't a problem nor is your works being
"inspired by the glibc implementation. Actually, Joel and I tried to compare
your work against the glibc-implementation trying to reach a conclusion if
including your works into RTEMS would violate the glibc's licensing, but we
remained uncertain.
I will try to review your works ASAP (hopefully this weekend).
Also, let me use this point in time to emphasize that the licensing issue
should not irritate you about your GSOC project.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
