[Bug 1636] Refactor Rate Monotonic Manager into a generic Periodic Manager
bugzilla-daemon at rtems.org
Thu Aug 12 14:39:40 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1636
--- Comment #13 from Gedare <giddyup44 at yahoo.com> 2010-08-12 14:39:39 CDT ---
(In reply to comment #7)
> Comments below
> + Patch is out of date for score/Makefile.am. No big deal. I fixed that.
> + missing } for C++ in rtems/.../periodic.h
Fixed
> + no user documentation. But not important see next.
The rate monotonic documentation is still correct. I can copy-paste it for the
periodic manager if/when we accept the design of the periodic manager.
> + If I am right, I think you rename rate_monotonic_period_XXX
> to rate_periodic_XXX and I can't accept that part of the patch. This
> would break API compatibility and although it can be argued that
> the rate monotonic name obscures the fundamental nature of the periodic
> blocking service being implemented, it is really the theoretical reason
> this manager exists. So can your periodicXXX be moved to ratemonXXX and
> fixed?
Please see other posts.
> + You can't have objects with Ids in the score. They all have to take
> pointers. You combine score handlers with object control structure to
> create API level objects. So this periodic thing in the core needs to
> change to more of a support service. I think it is close. I suspect
> you just need to remove the Object_Control field from the structure
> and add it at the ratemon level. You never really used the id anyway
> as best I can tell.
I need help with this. :) Some of the routines still use the Object_Id, so I
think that I need to create an object at the API layer, probably with an
Periodic_Manager_initialization just in the rtems/src/periodic.c. Then I need
some kind of structure that embeds both an Object_Control and a
Periodic_Control? Something similar to the old Rate_montonic_Control. This
will allow for the API to use/pass the Objects_ID. The periodic manager uses
the Object Id because it goes through the watchdog timer.
> + I think most of the style issues mentioned in the modular scheduler
> PR apply here.
I think I corrected these.
> I really like the idea of adding a "periodic blocking service" to the
> score. But use it to simplify ratemon_xxx and don't rename the current
> API.
I'm willing to revert to the original naming, but see other posts on this.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
