[Bug 1671] rtems_panic() in gxx wrappers
bugzilla-daemon at rtems.org
Thu Aug 12 06:39:51 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1671
Joel Sherrill <joel.sherrill at oarcorp.com> changed:
What |Removed |Added
AssignedTo|joel.sherrill at oarcorp.com |chrisj at rtems.org
--- Comment #1 from Joel Sherrill <joel.sherrill at oarcorp.com> 2010-08-12 06:39:48 CDT ---
This is Chris' code.
I would like to add that I think these methods need to be split one API method
per file. The last time I looked in detail all code in this area was in a
single file which is also bad for size.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
