[Bug 1662] termios.c: semaphore not deleted, consequently resulting in failure of rtems_termios_open
bugzilla-daemon at rtems.org
Wed Aug 11 10:47:08 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1662
Sebastian Huber <sebastian.huber at embedded-brains.de> changed:
What |Removed |Added
Status|RESOLVED |REOPENED
Resolution|FIXED |
--- Comment #10 from Sebastian Huber <sebastian.huber at embedded-brains.de> 2010-08-11 10:47:07 CDT ---
I think we have a bigger problem here. Originally I thought that we can delete
a binary semaphore even if it is locked.
We see here an example of a basic RTEMS file system issue. There is no way to
know if someone uses a file system node (in this case a driver). For a proper
clean up sequence we must ensure that
1. exactly one thread does the clean up,
2. prior to this all activities from other threads terminated, and
3. after the clean up begin all accesses from other threads return with an
error status.
If we initiate a clean up we need cooperation from other threads. They must
stop their activities and we have to wait for them. Currently the last close
initiates the clean up. This is wrong. Instead the last user should do the
clean up in case the instance is in a certain state.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
