[Bug 1662] termios.c: semaphore not deleted, consequently resulting in failure of rtems_termios_open
bugzilla-daemon at rtems.org
Tue Aug 10 12:39:46 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1662
--- Comment #5 from Joel Sherrill <joel.sherrill at oarcorp.com> 2010-08-10 12:39:43 CDT ---
Which test does this case show up on? Can you create a small test?
If this is with the test driver, I think it may be an issue with the test
driver.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
