[Bug 1475] SIZE_MAX
bugzilla-daemon at rtems.org
Mon Aug 9 10:10:50 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1475
Ralf Corsepius <ralf.corsepius at rtems.org> changed:
What |Removed |Added
Status|NEW |ASSIGNED
Target Milestone|2 |---
--- Comment #1 from Ralf Corsepius <ralf.corsepius at rtems.org> 2010-08-09 10:10:50 CDT ---
With RTEMS having begun to use SIZE_MAX, this bug now has visible impacts.
AFAICT, affected are all 16-bit targets with an rtems-gcc-toolchains <
gcc-4.5.0.
In particular:
avr-rtems4.10, h8300-rtems4.10, m32c-rtems4.10.
The bug shows as warnings when compiling rtems-4.11/testsuites with one of the
rtems-4.10 toolchains listed above. Likely (unverified), it also shows when
compiling rtems-4.10/testsuites with them.
Unfortunately, there is no fix in sight from me.
Instead, as these targets are the least important ones for rtems-4.10, I am
leaning towards upgrading these target's rtems-toolchains to gcc-4.5.x.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
