[Bug 1661] Coverage improvements: termios
bugzilla-daemon at rtems.org
Mon Aug 9 08:09:55 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1661
--- Comment #5 from Joel Sherrill <joel.sherrill at oarcorp.com> 2010-08-09 08:09:54 CDT ---
(In reply to comment #4)
> I am very opposed to "local externs" like this one and consider them to be bad
> style (They indicate a violation of the API and/or improperly implemented API):
> + extern Heap_Control *RTEMS_Malloc_Heap;
> static const rtems_termios_callbacks Callbacks = {
> NULL, /* firstOpen */
> NULL, /* lastClose */
It is an intentional violation of the API. But most of the cases (except
malloc04) are calling it to just get the amount of free space
(e.g. malloc_free_space()). I am testing a patch that should address
all but malloc04.
malloc04 is replacing the malloc heap with another one so it can test the
sbrk functionality in the malloc family. I only see two ways to do this:
+ add it to a .h file
+ add "malloc_get_heap/malloc_set_heap"
I don't particularly care. Which do you prefer?
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
