[Bug 1656] GSoC AIO patch
bugzilla-daemon at rtems.org
Mon Aug 9 00:52:45 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1656
--- Comment #4 from Alin Rus <alin.codejunkie at gmail.com> 2010-08-09 00:52:45 CDT ---
Ralf,
Joel had some valid comments but I addressed some of them in the google code
repo, so I suggest everyone should look at the repo. I plan to wrap things up
today.
I renamed all functions and structures as rtems_aio_*, if that's ok with you.
There's no test code yet, but there's a sample in
testsuites/samples/testrtems/aio
There is also an issue of initializing chains, that's why rtems_aio_init should
be used before using aio. Can this be done different?
I was not really sure about the license, that's why the files have no licenses.
The whole implementation is based on the glibc implementation which is under
gpl2.
I will update the google code repo later today, so please update your tree
before considering committing. I will announce this here.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
