[Bug 1365] Shell msdosfmt (format command) a NOOP with SD/MMC cards
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Fri Aug 6 18:06:38 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1365
Joel Sherrill <joel.sherrill at oarcorp.com> changed:
           What    |Removed                     |Added
         AssignedTo|joel.sherrill at oarcorp.com   |chrisj at rtems.org
   Target Milestone|4.10                        |Not Assigned
--- Comment #6 from Joel Sherrill <joel.sherrill at oarcorp.com> 2010-08-06 18:06:37 CDT ---
Is this something we will fix or should this be closed?
Is it applicable to 4.10, the head, etc?
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
