[Bug 1650] New: rtems_partition_return_buffer can be called several times
bugzilla-daemon at rtems.org
Tue Aug 3 01:32:08 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1650
Summary: rtems_partition_return_buffer can be called several
times
Product: RTEMS
Version: HEAD
Platform: All
OS/Version: RTEMS
Status: NEW
Severity: normal
Priority: P3
Component: cpukit
AssignedTo: joel.sherrill at oarcorp.com
ReportedBy: nbkolchin at gmail.com
Created an attachment (id=967)
--> (https://www.rtems.org/bugzilla/attachment.cgi?id=967)
error testcase.
rtems_partition_return_buffer has no protection for multiple calls:
Sample code:
rtems_partition_get_buffer(part_id, &buf);
sc1 = rtems_partition_return_buffer(part_id, buf);
sc2 = rtems_partition_return_buffer(part_id, buf);
Both sc1 and sc2 are equal to RTEMS_SUCCCESSFUL. Internally partition "memory"
member contains two "buf" inside Chain. And "number_of_used_blocks" is equal to
-1.
Proposal: Scan "memory" chain to prevent adding buffers that are already inside
chain. I didn't find any standard API for searchin data inside chain.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
